Author Topic: si unit and di unit  (Read 6809 times)
Offline sjefsrafsern
    • neptune og nemo`s fiskeside
  • Unit(s): 898/1198
  • Software: 6.740
  • Accessories: digitroll 5 ts cannonlink
si unit and di unit
« on: August 30, 2012, 05:15:38 AM »
Hi guys, if i add a 788 hd di to my boat and run both si ducer and di ducer on the transom. will i get interference if i run one unit 455khz and the other unit 800khz. (i d like to run both units at the same time)
regards stig
Re: si unit and di unit
« Reply #1 on: August 30, 2012, 09:37:20 AM »
No you should not get any interference on the Si or DI sonar if you are using different frequencies.
However, both units will still be transmitting and receiving on the 200kHz frequency and so have the chance of having sonar cross-talk interference.
Offline Rüdiger
« Reply #2 on: August 31, 2012, 04:34:01 AM »
Hi Stig
Yes, there are faults if you used DI and SI  simultaneously. I myself used for DI 83kHz and 800kHz for SI, there were still problems, though not significantly.
mvh
Rüdiger
« Last Edit: August 31, 2012, 06:01:37 AM by Rüdiger »
Finding is better than losing
Last post June 06, 2010, 07:37:56 PM
by fishmanmike
Last post January 11, 2011, 09:24:13 AM
Last post July 18, 2011, 03:52:09 PM
Last post November 22, 2011, 11:02:08 AM
Last post January 16, 2012, 01:20:22 PM
Last post August 25, 2014, 12:35:36 PM
