Author Topic: distance between 2 way points  (Read 21820 times)
Offline T.G
  • Unit(s): 898si
  • Software: v 6.180
« on: June 17, 2011, 02:53:14 AM »
hello i was wondering if there is a way on my 898si to measure the distance between 2 way points, with out my boat being one of them? would it be in the create a route section ? i had a look but could not figure it out
thanks T.G
Re: distance between 2 way points
« Reply #1 on: June 17, 2011, 08:32:09 AM »
No there is not.
« Reply #2 on: June 17, 2011, 04:25:23 PM »
HMMMM Maybe Humminbird should have bought lowrance instead of Navico....
Greg, are we falling behind?????
Offline T.G
  • Unit(s): 898si
  • Software: v 6.180
« Reply #3 on: June 17, 2011, 09:40:14 PM »
ok thanks for the reply, the reason i ask is ,while out in my boat yesterday i had to tow a fellow home who had broken down,while doing this i set my unit to record & slowly headed back to his ramp,on the way we passed some artificial reefs that have been put into our lake,now as i got close to some of these reefs i noticed that these reefs were slightly away from the marks that i have inserted,that were provided from our fisheries website here in aus.I zoomed right in & they were still off the mark, would using map offset correct this,bearing in mind i do not have a navionics card ,just the standard base map & having watched the how to map off set video, it explains to use a structure like a bridge to go off, this system does not have anything like that.
thanks T.G
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
« Reply #4 on: June 18, 2011, 06:20:07 AM »
T.G Read this.       http://forums.sideimagingsoft.com/index.php?topic=52.msg99#msg99
http://forums.sideimagingsoft.com/index.php?topic=462.0
        GARY
« Last Edit: June 18, 2011, 06:29:41 AM by stillbear »
Offline T.G
  • Unit(s): 898si
  • Software: v 6.180
« Reply #5 on: June 23, 2011, 05:44:37 AM »
Hi thanks for the links Gary,they told me just what I needed to know, I will try to use the search function better next time.
T.G
Offline stillbear
  • Stillbear
« Reply #6 on: June 23, 2011, 07:15:26 PM »
I am glad you got it. Gary
Last post May 27, 2011, 12:08:21 PM
Last post March 21, 2013, 12:40:37 AM
Last post September 16, 2014, 09:56:27 AM
by Sawyer
Last post July 05, 2016, 10:24:17 PM
by coldsteel
Last post January 09, 2017, 02:01:29 PM
Last post June 11, 2019, 10:46:10 AM
by ezfishn
Last post December 23, 2020, 10:01:00 PM
Last post July 17, 2024, 08:05:09 AM
by Kenai
