Author Topic: Gps points loaded on sd card from HB PC  (Read 14417 times)
Offline Smashman
  • Unit(s): 798ci si combo
« on: March 20, 2013, 10:18:11 PM »
I have manually added gps coordinates through HB PC onto a sd card. The dumb question is as follows:
what is best, to load them from the card onto the unit or just leave then on the card. I was thinking of having a few sd cards with for the different areas as Western Australia is a big place.
Or does the unit just keep them on the memory for the ones I load from the sd card?
Re: Gps points loaded on sd card from HB PC
« Reply #1 on: March 20, 2013, 10:42:40 PM »
Welcome to the forum. When you load the waypoints onto the SD card and stick it in the unit, the unit will automatically load them and keep them in memory.  The unit does keep them in memory, so you would have to export and delete the nav data each time when you want to insert a new card for a new area.
Offline Smashman
« Reply #2 on: March 20, 2013, 10:54:48 PM »
I also have another question. Do I need to go back and load the di update, or will the latest update cover this di?
« Reply #3 on: March 21, 2013, 12:40:37 AM »
The latest update will always include the previous updates before it.
Last post May 27, 2011, 12:08:21 PM
Last post June 23, 2011, 07:15:26 PM
by stillbear
Last post June 30, 2013, 12:30:02 AM
Last post August 11, 2013, 05:41:25 PM
by Austin358
Last post September 16, 2014, 09:56:27 AM
by Sawyer
Last post July 05, 2016, 10:24:17 PM
by coldsteel
Last post January 09, 2017, 02:01:29 PM
Last post August 15, 2017, 09:20:10 PM
