Author Topic: Spot lock leaves a lot of way points?  (Read 9599 times)
Offline Gattlin
« on: June 02, 2019, 02:02:39 AM »
It's been awhile sense I've posted on the forum so for that I apologize guys. I'm curious as to, is there a way to use spot lock and not have a way point added that I will just have to delete? This causes down time on the water so any and all helpful info would be mucho appreciated.
Just one last cast.
Offline bhgammon
  • Unit(s): HELIX C/M SI GPS G2N MEGA, 899 Si
  • Accessories: i-Pilot link
Re: Spot lock leaves a lot of way points?
« Reply #1 on: June 02, 2019, 11:37:48 AM »
Try using the "cancel" button when you want to leave the spot-lock position. This should be shown on your remote window.
BG- ;)
Offline Gattlin
« Reply #2 on: June 03, 2019, 03:05:53 AM »
So hitting the cancel button everytime? There has to be another way or the software needs an update. $2400 and I spend how much time deleting way points and the hit cancel button is just as bad. It takes away from the focus that should be fishing sry for the rant.
Just one last cast.
Offline bhgammon
« Reply #3 on: June 03, 2019, 04:15:31 AM »
The cancel command is right there on the remote along with the steer right & left commands. It only takes a second to press it and it clears the waypoint number so that you will use the same number over & over until you actually save a location to that number.
Offline Gattlin
« Reply #4 on: June 09, 2019, 02:28:03 PM »
Oh ok just trying to get past the learning curve  ;D
Just one last cast.
Offline ezfishn
« Reply #5 on: June 11, 2019, 10:46:10 AM »
What model TM are you using?
Last post January 25, 2010, 06:44:46 PM
Last post August 24, 2010, 06:29:50 PM
by eric3338
Last post May 23, 2012, 02:15:38 PM
by Weekend Warrior
Last post June 20, 2012, 12:11:18 PM
Last post March 18, 2014, 06:57:13 AM
by slabbacks
Last post September 16, 2014, 09:56:27 AM
by Sawyer
Last post May 13, 2018, 10:41:56 AM
by Sigler
Last post June 12, 2019, 01:29:43 PM
by Steve Schmidt
