Author Topic: Unit not reconizing gps  (Read 10426 times)
Offline Foster78
  • Unit(s): 987 SI
« on: June 11, 2011, 12:56:05 PM »
My unit is not reading gps. Is keeps saying no fixed postion and no temp reading or left side on side imaging. I reset defaults and still nothing. And I have a code 621sm.  Unit is a 987 Thanks
Offline George
  • Software: Always up todate
Re: Unit not reconizing gps
« Reply #1 on: June 11, 2011, 03:15:50 PM »
Foster
We could use a little history.
Was it working initially?
When did it stop working?
Have you changed anything before it stopped working?
Have you tried disconnecting and reconnecting everything to insure you have good connections?
Is there enough voltage going to your unit?
What is the layout of the equipment?
« Last Edit: November 03, 2011, 07:33:44 AM by George »
Offline Foster78
  • Unit(s): 987 SI
« Reply #2 on: June 11, 2011, 07:21:17 PM »
Everything was working fine last week. I unhooked everthing and tried it several time swith no luck with batterys fully charged.
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
« Reply #3 on: June 11, 2011, 07:47:53 PM »
Where are you at when trying to recieve signal?
Offline Foster78
  • Unit(s): 987 SI
« Reply #4 on: June 11, 2011, 09:43:29 PM »
At the lake and tried it at my house.
Offline Foster78
  • Unit(s): 987 SI
« Reply #5 on: June 11, 2011, 10:30:32 PM »
My unit was showing the unit was connected to gps but was showing no fixed position. Temp was not working and half of the side imaging either.
Offline stillbear
  • Stillbear
« Reply #6 on: June 12, 2011, 07:03:38 AM »
Foster78 have you got a buddy or another HB near so you can put your head on it ?  Gary
Offline Foster78
  • Unit(s): 987 SI
« Reply #7 on: June 12, 2011, 12:05:44 PM »
No but I did get the temp to work
« Reply #8 on: June 12, 2011, 12:07:45 PM »
foster.....what got the temp to work?????
Offline stillbear
  • Stillbear
« Reply #9 on: June 12, 2011, 01:37:47 PM »
Is that code on your map page if it is that is your zoom. Take it in or out.
Offline Foster78
  • Unit(s): 987 SI
« Reply #10 on: June 12, 2011, 02:06:13 PM »
I went into menus and got it to show. But it always has showed until yeasterday The code is showing on the dianostics. Under (est pos error) it says 621sm
« Reply #11 on: June 12, 2011, 07:08:38 PM »
I would guess that when you set defaults the temp reading was lost....glad you got it back.
Something still wrong with gps.  err of 651 sm it way too high.
As Gary asked,,,,can you swap the unit.
Offline Foster78
  • Unit(s): 987 SI
« Reply #12 on: June 12, 2011, 07:57:43 PM »
I will try
Last post March 28, 2010, 10:03:40 PM
Last post June 06, 2010, 07:37:56 PM
by fishmanmike
Last post December 21, 2010, 09:01:07 PM
Last post January 11, 2011, 09:24:13 AM
Last post January 28, 2011, 11:24:01 PM
Last post May 15, 2011, 06:00:44 PM
Last post August 31, 2012, 04:34:01 AM
by Rüdiger
