Author Topic: Does the Chart Speed affect distance calculations in HumViewer?  (Read 7500 times)
Offline gobio
  • Unit(s): 798 c si external GPS
Hi.
Is it possible that a false Graphspeed/Chart speed make false distance display when i look the sonarlog in the Humviewer?
I drive with 3-4 mph and have a Graphspeed/chart speed of 4. What happens when i take 10?
friendly
Mirco
Re: Does the Chart Speed affect distance calculations in HumViewer?
« Reply #1 on: July 28, 2010, 05:31:11 PM »
Mirco,
I split this topic off from the SI Settings topic since it was a totally different question.
The chart speed does not affect the recording.  It is only a playback or realtime feature on the unit itself.
I am not sure if HumViewer uses the boat speed in its distance calculation or not.  I dont think so.  If you are recording at higher speeds, the objects will be smaller than actual size since the number of pings per foot is less.  And conversely, if you are going too slow, the images will be elongated and will measure longer than normal.
Hope that helps,
Offline gobio
« Reply #2 on: July 29, 2010, 03:55:06 AM »
Hi.
Thanks for your answer and making a split of the topic.
It helps to understand it better and in the future i think i test it out.
friendly Mirco
Chart Speed
Started by Carl 798c SI
Last post July 11, 2010, 05:16:58 PM
Last post January 16, 2012, 04:18:09 PM
Last post March 14, 2012, 10:36:50 PM
Last post July 31, 2012, 03:33:50 PM
by Jim Jack
Last post August 11, 2013, 04:02:53 PM
by Tyee Hunter
Last post July 22, 2013, 11:26:34 AM
by johnnytherock
