Author Topic: Twin sonar units  (Read 6241 times)
Offline XgonefishinX
  • Unit(s): 797c2
Twin sonar units
« on: May 16, 2011, 06:14:13 PM »
Hi I own a 797 sidescan how can I add a di unit to work together
Offline ffmedic147
  • Unit(s): 998cnvb 958cnvb
  • Software: Whatever Works
  • Accessories: ethernet cable
Re: Twin sonar units
« Reply #1 on: May 16, 2011, 07:16:26 PM »
Explain what your asking a little better. Are you trying to add another 797?
Offline Roddy
  • Scan,scan and rescan
« Reply #2 on: May 16, 2011, 10:13:10 PM »
Xgone; I have a 797 SI unit and a 570 DI unit running at the same time. Xducers are seven (7) feet apart. units are set to different Freq. I have had no trouble with this setup.
Scan,Scan and Rescan Roddy
« Reply #3 on: May 17, 2011, 12:55:24 PM »
What are you meaning by “work together”?
Are you meaning linked together so that the units share some form of data between them or are you meaning that both can be run on the same boat at the same time without interfering with one another?
With the 797 unit you are limited to the InterLink accessory for linking it to another unit.
With two sonar units on the same boat there is always the possibility of getting sonar-to-sonar interference as most of our units use the same 200kHz frequency for the 2D sonar.  If you do get this; try turning on and up the Noise Filter menu on the unit that is showing the interference.  If that does not help enough than try setting the Lower Range menu to a manual setting that is different than the other unit.
by garinis33
Last post October 06, 2010, 09:30:20 AM
by Irishrover
Last post June 25, 2012, 12:24:44 PM
Last post December 16, 2010, 12:59:03 PM
Last post March 07, 2011, 06:41:14 PM
Last post February 11, 2011, 07:33:21 PM
by kosmo
Last post March 15, 2011, 09:33:09 PM
by Fishfinger
Last post April 04, 2011, 01:55:51 PM
