Author Topic: Sharing sonar views between units  (Read 8466 times)
Fishfinger
  • Guest
« on: March 15, 2011, 05:45:59 AM »
I am planning on installing a 898c si with an additional dual beam/high speed transducer. Can I link a second unit to the 898 and have it display the signal from the added dual beam transducer? If my second unit is a si unit would it display the si signal from the 898 as well? I seem to be having a hard time getting this answer and would appreciate any input. Thank you.
Offline Trytoofish
  • Software: 2.0, 7.51,
Re: Sharing sonar views between units
« Reply #1 on: March 15, 2011, 08:47:47 AM »
I think if both units are Ethernet capable,and they get the Ethernet updates the answer will be yes,but maybe someone else knows for sure. you wont be able to see both sources at once, but one at a .
You can download the Ethernet manual here.
http://store.humminbird.com/media/document/Ethernet_Manual.pdf
Try Too Fish  Forced To Work
Fishfinger
  • Guest
« Reply #2 on: March 15, 2011, 09:33:09 PM »
Appreciate your input and the link. I read some of the manual and I still am not sure what the answer is.
Last post April 29, 2010, 08:51:20 AM
Last post June 27, 2010, 12:07:05 AM
Last post August 23, 2010, 04:21:39 PM
Last post May 17, 2011, 12:55:24 PM
Last post February 05, 2013, 11:45:54 PM
by EZM
Last post July 29, 2013, 01:48:50 PM
Last post October 23, 2013, 08:29:29 AM
Last post August 24, 2015, 05:26:41 PM
by Ronquest
