Author Topic: Interlink Problem  (Read 7681 times)
Offline Sto
  • Unit(s): 798,797
  • Software: 5.450,5.450
  • Accessories: Interlink,I-pilot
Interlink Problem
« on: June 21, 2014, 05:46:46 PM »
I have 798 and 797 connected with interlink. 797 keep losing interlink, erased interlink, no way points on either unit.
And both running 5.450 software. Any ideas?
Re: Interlink Problem
« Reply #1 on: June 22, 2014, 12:06:41 PM »
Greg is the Interlink info guy...
He should check in Monday...
« Reply #2 on: June 23, 2014, 12:47:05 PM »
Welcome to the Humminbird Side Imaging Forums Sto.
You should try swapping the connection ports that each unit is using.  Do so by swapping the connection cables to the opposite connections on the InterLink.
If that does not help you can try resetting the InterLink and you units by first this procedure:
http://www.humminbird.com/Category/Support/FAQ/InterlinkChangeOutsideNetwork/
and if that does not help by this one:
http://www.humminbird.com/Category/Support/FAQ/InterlinkPhantomWaypoints/
Last post January 26, 2011, 12:12:37 PM
by panman_va
Last post March 03, 2011, 02:44:11 PM
Last post April 01, 2011, 11:44:30 AM
Last post May 11, 2011, 12:26:05 AM
by LocDown
Last post August 10, 2011, 02:43:29 PM
Last post December 12, 2011, 02:36:56 PM
Last post February 03, 2012, 08:35:00 AM
