Author Topic: Interlink problem  (Read 9820 times)
Offline uncle j
  • Unit(s): 997 SI NVB
Interlink problem
« on: March 02, 2011, 07:53:07 PM »
Have a 997 & 958 w/ interlink and have downloaded the new software. It disconnects and connects about every 2 minutes. I don't think that is normal but don't know. Other than that everything is perfect.
Offline LMH Steel
  • Unit(s): 1197C SI and 1197C SI
  • Software: 5.430
  • Accessories: Now connected with Ethernet cable.
Re: Interlink problem
« Reply #1 on: March 03, 2011, 07:52:06 AM »
I have the same problem some days. I was told that there is a new update coming shortly that will connect the two units with an ethernet cable instead of using the interlink box. Should be in the next week or two.
Offline panman_va
  • Unit(s): 997C, 858C
  • Software: 997 5.45, 858 5.50
  • Accessories: Interlink, XM Weather
« Reply #2 on: March 03, 2011, 08:57:12 AM »
The 997 is not ethernet capable so Interlink is the only way to connect it.
My 997 would lose connection when it was the #1 unit. I changed it to #2 with my 858 on #1 and everything works fine. I'm using 4.995 BETA software on both units.
« Last Edit: March 04, 2011, 09:18:11 AM by panman_va »
Keith
Offline LMH Steel
  • Software: 5.430
« Reply #3 on: March 03, 2011, 10:50:05 AM »
Possiably thats what the new update is for, to make it ethernet capable? I dont know but that information came from someone that knows.
« Reply #4 on: March 03, 2011, 02:44:11 PM »
The 997 is not Ethernet capable even if it had the software to be (which it does not and will not get) because it does not have an Ethernet connection.  The 998 does but not the 997.  So InterLink is the only way to go.  Call the Humminbird Customer Resource folks about getting the 4.995 software for both of your units.
Last post August 29, 2012, 10:51:48 AM
Last post January 26, 2011, 12:12:37 PM
by panman_va
Last post April 01, 2011, 11:44:30 AM
Last post May 11, 2011, 12:26:05 AM
by LocDown
Last post August 10, 2011, 02:43:29 PM
Last post December 12, 2011, 02:36:56 PM
Last post February 03, 2012, 08:35:00 AM
Last post June 23, 2014, 12:47:05 PM
