Author Topic: 997C SI Sonar reading after 2011 update  (Read 11443 times)
Offline Jasta
  • Unit(s): 797SI, 997SI,
  • Software: 4_960 & 4_950
  • Accessories: Weathersense, Interlink
« on: April 12, 2011, 08:55:01 PM »
I just updated my 997S CI to the newest version following all of the directions.  Now when the boat is on the trailer in my garage, and I cycle through the sonar views, there is no depth reading.  I've got my screen readout selections set properly but no depth reading.  I've cycled the unit on and off several times and on one particular cycle, I got a depth reading that flashed.  When I shut the unit off and on again, the depth reading went away.  I've run through the simulation mode and depth is displayed there.
My 797cSI on the bow reads a depth when out of the water.  I understand that the reading would be inaccurate, but I don't even get a readout.  ie: "0.1".
I live in Minnesota so getting on the water to test is not an option right now.  Suggestions?
Offline panman_va
  • Unit(s): 997C, 858C
  • Software: 997 5.45, 858 5.50
  • Accessories: Interlink, XM Weather
Re: 997C SI Sonar reading after 2011 update
« Reply #1 on: April 13, 2011, 08:20:58 AM »
The readout should be there when you get the boat in the water. The same happens on both my 997 and 858.
Keith
« Reply #2 on: April 13, 2011, 12:44:48 PM »
I've noticed that too on my unit.
The software engineers probably decided that why display the depth at all if it is incorrect or not applicable.
« Reply #3 on: April 13, 2011, 01:11:42 PM »
Mostly that is the way it works out of water.
Try this.  put a 5 gallon bucket of water under the boat and stick the transducer in.....
It probably needs to be wet?? or have water as a medium not air..
It wont be accurate but it will read or rather display depth....
Offline Jasta
« Reply #4 on: April 13, 2011, 07:26:55 PM »
THanks Guys....Interestingly enough, last night, I came home from work and turn the unit on and voila, the depth reading was back.  I cycled it on and off several times and it was fine.
Crazy!
Offline FlatsFokker
« Reply #5 on: April 13, 2011, 10:49:26 PM »
Maybe your dog hiked a leg on it ;D
Last post April 29, 2009, 07:25:20 PM
Last post January 12, 2011, 07:59:42 PM
by mt72916
Last post February 07, 2011, 06:38:57 PM
by kosmo
Last post April 24, 2011, 10:20:09 PM
Last post October 07, 2011, 07:51:27 PM
by DiveExplorer
Last post May 13, 2012, 05:32:59 PM
by w2f4
Last post October 23, 2012, 06:36:34 AM
by LLCC
Last post October 30, 2012, 06:02:10 PM
