Author Topic: 797c and 997c Sonar Menu Settings Comparisons  (Read 14183 times)
« on: April 29, 2009, 07:25:20 PM »
Quote
My 997 out preforms my 1197 don't understand why?? Help !!
My Set up: Both units run off the same transducer with a switch for back and forth viewing. The settings are as what I can see the same.. The 997 runs great from eather positions bow or drivers seat position. The Problum: The 997 is much much more detail and clearer imageing. The 997 will show fish hooks for fish the 1197 eather don't show anything or shows a blob of color? The side imaging is more detail also where the 1197 is fuzzy and unclear?? I have been working on this for 4 months?? Need help from a higher power...... Here are some pits to show
The top is the 1197 and the bottom is the 997. notice the hooks on the 997 the 1197 will not show it shows them as blotches on not at all, pluss notice the fuzzy or cloudy side imaging on the top one as apposed to the clearer more defined bottom photo. These photos don't show the extent of the difference between the two units. On the lake it very noticeable...
I think we established that the images were from a 997 and a 797 in the other post.  http://www.xumba.scholleco.com/viewtopic.php?t=1514
Here are the PDF downloads taken from the 997 and 797 for the Sonar Menu section of the manuals.  I would compare these and make sure all the settings are the same.
Again, make sure you are in the ADVANCED USER MODE on both units before checking the settings.
Also, which transducer are you using, the one that came with the 997 or the 797?  They are different and you would need to set the 997 up to use the one for the 797.
997 SONAR MENU SETTINGS - Download
797 SONAR MENU SETTINGS - Download
Good Luck,
« Last Edit: April 29, 2009, 07:42:42 PM by RGecy »
Last post May 26, 2009, 11:15:20 PM
Last post March 02, 2010, 02:14:17 PM
Last post February 11, 2011, 04:16:42 PM
Last post September 04, 2013, 08:31:28 AM
Last post April 24, 2014, 03:27:47 PM
Last post October 10, 2016, 07:04:29 PM
Last post May 25, 2017, 08:16:21 PM
by wolfgrw
Last post May 28, 2022, 02:29:16 PM
by Swann
