Author Topic: Mounting SI ducer with twins  (Read 6144 times)
Offline magnumdeke
  • Unit(s): 798c SI NVB
« on: January 19, 2011, 07:13:34 PM »
Will I get interference with the SI ducer, with these motors? where is the best spot to place a mounting board and transducer to get it to work properly?
[imghttp://i831.photobucket.com/albums/zz239/Magnumdeke/Transmount1.jpg]http://[/img]
« Last Edit: January 19, 2011, 07:17:28 PM by magnumdeke »
Wayne P.
  • Guest
Re: Mounting SI ducer with twins
« Reply #1 on: January 19, 2011, 07:59:53 PM »
Next to the hull drain but not inline with the bottom rib. BUT that strap on the hull bottom parallel with the transom is going to create a lot of water disturbance/bubbles and you may not get good 2D performance when on plane.
« Reply #2 on: January 19, 2011, 08:47:25 PM »
magnumdeke,
Are the motors trimmed all the way down?  If so, you look like you have pretty good clearance side to side, but you will most likely have issues with turbulence in 2d and possibly SI.  I have to agree with Wayne on the strap.  The V hull is also going to cause little eddies that will interupt the SI sonar signals.  Although its not really a deep-V, you may notice it mostly with 455khz.
I would give it a try and see how your relults are.  But, you may have to go back and add a second SI transdcuer with and LR-Y cable.
Let me know if I can help with anything else, and welcome to the forum.
Offline magnumdeke
« Reply #3 on: January 20, 2011, 09:18:18 AM »
Those motors are old school manual trim set one hole to from the top, did not know I could do a left/right dual ducer hope not to due to price but will do if necessary! I am hoping that when trolling it will be clear. High speed as important to me
« Reply #4 on: January 22, 2011, 11:56:15 AM »
The recommended clearance for the big HDSi transducers is seven inches, which you just have, but add on a mounting plate and you may have some blockage.  Is there some way of temporarily mounting the transducer and mounting plate that does not involve drilling holes in the transom?  Make sure that this is only a low speed test!  We have successfully used 3M VHB tape (very high bond).  I’ve been told this is the same stuff sold in auto parts stores to hold chrome on cars.
Last post March 05, 2010, 02:44:55 PM
by Llunker
Last post April 20, 2010, 06:43:25 AM
by YankeeDoodler
Last post October 04, 2010, 07:03:19 AM
by Wayne P.
Last post March 15, 2011, 04:34:20 AM
Last post December 09, 2011, 01:26:06 PM
Last post January 05, 2012, 02:09:34 PM
Last post June 27, 2014, 12:20:45 PM
by hays47
Last post September 11, 2014, 09:58:14 AM
