Author Topic: Installation Pics of SI ducer and Custom L- bracket  (Read 11980 times)
Offline Llunker
  • Team Llunker
  • Team Llunker
    • Ultimate Lunker Fishing Forum
  • Unit(s): 997c SI
  • Software: 4.75
  • Accessories: SI with in-hull transducer as well
« on: March 04, 2010, 08:43:03 PM »
I finally got it on tonight and i will post other photos when i finish.  I am also going to be putting in a XP 9 20 shoot thru for the bilge pump area for high speed travel.
but here is the hard part in.
El Grande Lures Field Staff
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
Re: Installation Pics of SI ducer and Custom L- bracket
« Reply #1 on: March 05, 2010, 07:06:45 AM »
Randy,
could you post a picture seen from behind with the outdrive down? I wonder how far you're away from the prop and how much side stand off is.
the bracket looks interesting. Where's this from?
Regards / Harry
YES,......
WE SCAN!
Offline Llunker
  • Team Llunker
  • Team Llunker
  • Unit(s): 997c SI
  • Software: 4.75
« Reply #2 on: March 05, 2010, 08:02:26 AM »
The Name is Bobby,
The Bracket is custom made by a friend of mine named Scap(uk--english name I  think--he definitely  has the accent).  You can find his handwork here
http://www.transducershieldandsaver.com/home/
Here is a photo from behind --which really doesn't show much except the mount coming flush with the base of the Jackplate.
This guys Specializes in working with Custom Brackets for Jackplates for the HB units like the SI unit.  Ths is placed below the sponsons  and the jackplate is a 9"setback plate.  But This is 95% of the time where we place them on Bass Boats and it protects and "saves" that Tranducer from being hit my trees and rock.
Hope you like it and if you need anything --just askmy buddy to make it for you.
Bobby
oh and then of course i am going to run my XP 9 20 in hull shoot thru ducer here inside the boat in the bilge pump area--this is a Test spot here with it in place(just not glued down yet--as i have not tested the run on this spot--need to do a little sanding first)
XP 9 20 --Favorable spot for this ducer and run both ducers off of a (AS SIDB Y (y cable)).  For high Speed Travel --no need for a switch either as this cable takes the 2-d portion away from the SI unit.
Hope this helps
« Last Edit: March 05, 2010, 08:26:02 AM by Llunker »
Offline Llunker
  • Team Llunker
  • Team Llunker
  • Unit(s): 997c SI
  • Software: 4.75
« Reply #3 on: March 05, 2010, 02:44:55 PM »
Head unit is on today I went from this today
To THIS !!!!
Notice the GPS puck --no holes in the boat for that thing !!!
Last post July 14, 2010, 12:12:25 AM
by benamen
Last post June 16, 2012, 07:20:49 AM
by JudoJeff1234
Last post October 15, 2012, 04:21:15 PM
Last post October 14, 2012, 01:06:22 PM
by riven1950
Last post April 23, 2024, 02:03:05 PM
by Kenai
Last post February 22, 2014, 11:24:29 AM
by slonezp
Last post February 26, 2014, 09:35:00 PM
by WI Bad Bass
Last post March 11, 2014, 09:59:57 PM
by Stymie
