Author Topic: HumViewer - Viewer of humminbird files  (Read 385200 times)
Team CTM
  • Guest
Re: HumViewer - Viewer of humminbird files
« Reply #250 on: November 11, 2013, 04:39:16 PM »
That would be very nice of you as I really want to use this piece of software on my mac :)
Offline peterv6i
  • Unit(s): 998ci
  • Software: 4.500
  • Accessories: 998ci
« Reply #251 on: February 05, 2014, 07:25:48 AM »
Is there any way to collaborate on humview? as open source project?
Maybe it will be nice to correct zoom option and add option to rotate zoomed image , save as jpg ...
upload video directly to youtube, integrate google maps into gps track...
« Last Edit: February 05, 2014, 07:30:12 AM by peterv6i »
Offline michbarr
  • Unit(s): 398SI
  • Software: 4
  • Accessories: none
Re: HumViewer - Viewer of hummingbird files - Mac version
« Reply #252 on: March 21, 2014, 01:49:04 PM »
I am not able to get humviewer to run on my Mac running 10.8 OS.  Is there any upgrade of Humviewer that will work on modern mac OS computers?
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #253 on: March 22, 2014, 12:50:33 AM »
After three attempts to get HumViewer to run on my iMac ( 10.6.8 ), I just gave up and bought a Windows 7 laptop.
HumViewer adds 10 times the value to the Humminbird scanning experience. I thank Martin every day for the program.
Offline peterv6i
  • Unit(s): 998ci
  • Software: 4.500
« Reply #254 on: March 22, 2014, 09:59:06 AM »
I think the humviewer can be run from Mac and Linux...
You must have java 1.6 version installed..
Then you go into command promt or terminal mode...
Go to directory where Humviewer is installed and type:
java -Xms128m -Xmx1024m -classpath jar\HumViewer.jar;ext\JMF\lib\jmf.jar;ext\JMF\lib\customizer.jar;ext\JMF\lib\mediaplayer.jar;ext\JMF\lib\multiplayer.jar;ext\log4j\log4j-1.2.15.jar;ext\forms-1.3.0\forms-1.3.0.jar HumViewer.HumViewer %1 %2 &
I will try monday morning on linux system..
« Last Edit: March 22, 2014, 10:03:09 AM by peterv6i »
Offline GWDawg1
  • Unit(s): Solix 12, Solix 10
« Reply #255 on: March 25, 2014, 07:10:21 PM »
Anyone had any compatibility issues with Windows 8?  Everytime I try to save a screenshot it only saves one side of the Side Imaging.  Tried everything with no luck.
Offline peterv6i
  • Unit(s): 998ci
  • Software: 4.500
« Reply #256 on: March 26, 2014, 03:35:10 AM »
Try to hit "PrintScreen" on keyboard and then paste image inside some graphic program like (pain.net) (http://www.getpaint.net/)
Offline GWDawg1
« Reply #257 on: March 26, 2014, 07:05:07 AM »
I can print screen and the image is correct, however, when use the "Save Snapshot" in the software the image only saves one half of the SI image.  Worked all day on this yesterday, reloaded software, etc. with no success.
Offline chuck41
  • I'd rather be fishin'
    • Lake Ouachita Arkansas
  • Unit(s): 798ci si di Combo
« Reply #258 on: April 10, 2014, 12:30:41 AM »
Humviewer works great on both my Windows Vista and also on my Linux-Ubuntu box using WINE to create a Windows environment.  Haven't been able to get the Google Earth to work in the WINE environment so that part doesn't work but everything else seems fine.
A bad day on the lake is still better than a good day at work!
Offline Wobby
  • Unit(s): 899ci HD
« Reply #259 on: April 29, 2014, 05:59:49 AM »
Hi
Ive tried downloading the program from http://humviewer.cm-johansen.dk and it keeps coming up as corrupted.
Is there somewhere else to download a copy?
thanks
wobby
Offline peterv6i
  • Unit(s): 998ci
  • Software: 4.500
« Reply #260 on: April 29, 2014, 07:27:31 AM »
Have you tryed to download a HumView setup file for PC?
tryed now and works well..
Offline Wobby
  • Unit(s): 899ci HD
« Reply #261 on: April 29, 2014, 08:22:43 AM »
Thanks  Peter
ive tried running it and also saving then runing and it still comes up as "set up files corrupted"
any other suggestions?
wobby
Offline peterv6i
  • Unit(s): 998ci
  • Software: 4.500
« Reply #262 on: April 29, 2014, 08:41:00 AM »
Try to download from my google drive... (it's a zip file)..
Just unzip it somewhere on c:\  and ther run runHumViewer.bat
https://drive.google.com/file/d/0B6Z9wNTXyUEebGhKQ2NTTVlXTU0/edit?usp=sharing
If you don't have java installed please install the java from http://www.java.com/en/download/index.jsp  (java it's not included in my zip file)..
« Last Edit: April 29, 2014, 08:48:34 AM by peterv6i »
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #263 on: April 29, 2014, 11:58:31 AM »
Wobby
    Are you using Internet Explorer for your browser? Try Firefox or Chrome. I recall someone posting that was how they got it to work.
Offline Wobby
  • Unit(s): 899ci HD
« Reply #264 on: April 30, 2014, 07:23:45 PM »
Thanks peter I downloaded from your google and also tried using Chome to downlaod as Mike suggested, the chome download worked so im up and running.
thanks
wobby
Offline ricker
  • Unit(s): 1198c
« Reply #265 on: May 19, 2014, 12:36:59 PM »
Hello,
Is there a "best" combination of firmware, Java and HumViewer that will allow subrecordings?  I have tried several versions to make the subrecording function work to no avail.  They have changed the firmware versions so many times that maybe I am just using the wrong combination?
Rick
Offline greenmachine
  • Unit(s): 798ci
« Reply #266 on: May 20, 2014, 02:31:50 PM »
Running Humviewer version 86 and can't get it to export a CSV of my data.  KML exports fine and I can then use a converter to get the data I need in the right format, but its a tedious process and would love to be able to get CSV.  anyone have any advice?
Offline peterv6i
  • Unit(s): 998ci
  • Software: 4.500
« Reply #267 on: May 21, 2014, 02:18:01 AM »
yap.. in 86 the export in csv does not work.....
What type of data do you need from csv file?
  • Unit(s): 798ci
« Reply #268 on: August 20, 2014, 07:07:31 PM »
Wow, sorry for my late reply.  I ended up exporting as KML, then opening KML in a text editor, grabbing the bit with the lat/long/depth info, saving as text and opening in excel, text-to-columns in excel, and then I finally had a good file.  It sounds like a lot but wasn't really so bad, now I am able to open in GIS and theoretically do contours there, though the contours script keeps crashing with so many points.
« Last Edit: August 20, 2014, 07:08:48 PM by greenmachine »
  • Unit(s): 798ci
« Reply #269 on: July 01, 2015, 04:20:57 PM »
I'm having some issues with corrupt files.  I had some errors with my memory card while recording, and now the files are not opening properly.  I know they contain data, but humviewer locks up when I try to load them.  Any ideas?
« Reply #270 on: July 01, 2015, 06:30:03 PM »
Are the files and folders still in tact enough to create a RECORD folder on the SD Card (with the files in them) and test the recording in the HB head unit ... ??
  • Unit(s): 798ci
« Reply #271 on: July 01, 2015, 06:58:17 PM »
The RECORD folder and .DAT files are all there, along with all corresponding .IDX and .SON, but the ones that won't load into humviewer also won't play back on the head unit.
« Reply #272 on: July 02, 2015, 03:59:50 PM »
PM Robert to see if he will let you email your RECORD folder to him to see what may be missing in the files ...
http://forums.sideimagingsoft.com/index.php?action=profile;u=1
« Last Edit: July 02, 2015, 04:01:06 PM by rnvinc »
Offline SLYDoggie
« Reply #273 on: September 08, 2015, 01:29:28 PM »
I just downloaded the latest version of HumViewer but it won't read my Onix 10 .DAT files. It gives me an error saying that is isn't a valid 64bit DAT file. I assume that HumViewer doesn't currently support the ONIX finders but was wondering if that is coming.
« Reply #274 on: September 08, 2015, 09:14:03 PM »
Correct in that Humviewer won't play Onix recordings ...
I don't know about Martin ... He hasn't checked in for quite some time ...
Offline peterv6i
  • Unit(s): 998ci
  • Software: 4.500
« Reply #275 on: September 16, 2015, 01:57:50 AM »
Does Onix have different file format than 998?
I tryed to contact Martin several times.. I'am interested to work on HummViewer as open source project but...
the only way to get the source was a decompile of latest HummViewer.....  ???
Offline JEVSkeeter
  • Unit(s): Onix 10 SI, Helix 12, 1199, 999, 360
  • Software: Current
« Reply #276 on: October 09, 2016, 01:06:51 PM »
Good day. I am still having issues downloading a MAC version. Any assistance would be appreciated.
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #277 on: October 09, 2016, 09:57:54 PM »
JEVSkeeter
     To the best of my knowledge no one has been able to get Humviewer to work on a Mac.  I resorted to buying a Windows laptop.  Martin has created a great program. I had hoped Peter would be able to contact him.
Offline bigbear1983
  • Unit(s): helix 7 si/di
« Reply #278 on: February 15, 2017, 11:04:35 PM »
Hi, new to this forum. I've tried to download the humviewer program. It appears to go though the steps but when I click on the open file I get the following message: windows cannot access the specified device, path, or file. You may not have the appropriate permission to access item."  Can some one point me to a cure?
        Thanks Mike
« Reply #279 on: February 16, 2017, 11:30:18 PM »
        Thanks Mike
Did you download Humviewer from here ...??
Did you save the application file to your PC 1st and then try to run the application ...??
« Last Edit: February 16, 2017, 11:31:41 PM by rnvinc »
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #280 on: February 17, 2017, 12:08:57 PM »
Just had my computer wiped clean (corrupted download) and Win 7 Pro installed.  Tech installed Norton AV and all updates.  Tried to download HumViewer and Norton said it contained a virus and wouldn't go any farther.  I'm guessing he was using Internet Explorer.  Will talk to him later today.  I'll let you know how this works out.  He hates Chrome and it's the one I like.  We'll see.
Offline bigbear1983
« Reply #281 on: February 17, 2017, 02:18:44 PM »
Hi, yes I did try from that address. I clicked on it, hit save and when it finished and asked if I wanted to run,   I hit that and that is when I get that message.
« Reply #282 on: February 17, 2017, 09:41:52 PM »
Did the Humviewer program successfully install ...??
Look in your Programs and see if Humviewer is there ...
« Last Edit: February 17, 2017, 10:00:50 PM by rnvinc »
Offline bigbear1983
« Reply #283 on: February 18, 2017, 11:40:17 AM »
Hi, I looked in the program files and there is no humviewer in there.
« Reply #284 on: February 18, 2017, 07:33:05 PM »
Humviewer also requires Java 1.6 ..... Did you makes sure you have that.
« Reply #285 on: February 18, 2017, 07:41:20 PM »
I have sometimes have had to do a temporary disable of virus protection when downloading software. I have heard others complain of download issues with IE ......I have good luck with Fire fox or Chrome.
Offline bigbear1983
« Reply #286 on: February 18, 2017, 09:20:41 PM »
Well, I downloaded the newest Java, disabled my firewall and still get the same message as before, about not having appropriate permission to access. I also got a message from Norton saying that this file is not safe, though it says there are hundreds of users. It says "Threat type: Insight Network Threat There are many indications that this file is untrustworthy and therefore not safe". It also says - setup-version-86.exe   Threat name "WS.Reputation.1" Though when I looked that up, it just gives a generic type threat rating. Guess I'll have to play around with settings and see what happens.
Offline bigbear1983
« Reply #287 on: February 18, 2017, 09:42:12 PM »
UpDate.   I finally believe I got it. Had to mess around with Norton and found a way to allow this program.                        Thanks for all the help
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #288 on: February 19, 2017, 10:58:59 PM »
HumViewer installed today by the computer tech.  He used IE (told you he hated Chrome) and by disabling Norton AV while downloading the program.  Restarted Norton and ran a scan.  Norton found HumViewer saying it contained malware.  He had Norton disregard it and everything works for now.
  Threat name "WS.Reputation.1" is the name of the file Norton doesn't like.   Here is a link to Norton Community updated June 2016 discussing this file.
           https://community.norton.com/en/forums/clarification-wsreputation1-detection
Offline fshndude
  • Unit(s): Helix 8 DI+, 9 G2N, Helix 12+ A/C Pro,
  • Accessories: Ulterra i link, ethernet,
« Reply #289 on: May 07, 2017, 09:57:51 PM »
I know this is an old thread but I just tried to play a recording from my Helix GN2. Won't play? I guess I'll have to record on the console 899. Any thoughts folks?
Dave in Currituck,NC
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #290 on: May 07, 2017, 11:50:45 PM »
Dave
     I think I saw a post that said Humviewer only works with the core units. Your 899 should be good to go.
Offline fshndude
« Reply #291 on: May 08, 2017, 07:25:29 AM »
Are we going to get an up dated version to work with the newer units? Would be nice.
« Reply #292 on: May 08, 2017, 11:34:37 AM »
This is a 3rd party product not supported by Humminbird .... maybe you can send a message on the site where you downloaded it.
Offline fshndude
« Reply #293 on: May 08, 2017, 11:56:42 AM »
Thanks Bob, I read the whole old post, but the fellow that wrote the program is not responding to anybody any more. I was playing around with my Auto Chart program and I had 2d playing on my Auto Chart. I might have to buy another program like reef master to view my recordings from the Helix GN2.
« Reply #294 on: May 08, 2017, 12:44:20 PM »
Yellowfin is another one ..... not sure what all it supports
Offline navionic
« Reply #295 on: September 09, 2022, 11:43:11 AM »
Please  .exe file this programm
Last post May 01, 2013, 12:20:48 PM
by sjbelaire
Last post January 19, 2010, 01:17:46 PM
Last post April 22, 2012, 07:18:25 PM
by fishshtick
Last post March 15, 2014, 01:08:21 PM
Last post June 19, 2015, 08:55:01 AM
Last post August 22, 2015, 06:06:41 PM
by bigdaddyguns
Last post October 17, 2017, 08:00:10 PM
by ckd022
Last post April 30, 2018, 12:17:21 PM
by D Johnson
