Author Topic: Extracting GPS & Depth from Humminbird SONAR files  (Read 20414 times)
Offline MikeM24108
  • Unit(s): HELIX 5 CHIRP SI GPS G2 | HELIX 5 Series
  • Software: Not sure - current
  • Accessories: None
« on: October 08, 2017, 06:25:07 PM »
I have a Humminbird HELIX 5 CHIRP SI GPS G2 and I'm doing some fresh water (limnology) marine archaeology with associated lake mapping.  I have searched, but can't find a method of extracting the LAT, LONG, DEPTH info from the Humminbird SONAR files.  I need to get this in some type of ASCII format (CSV, etc., even unformatted if only available) so that I can import it to EXCEL and modify data for subsequent export to a more sophisticated scientific contouring program.
Does anyone know where I can find a 3rd party software that can do this extraction.  I can deal with extracting more info than the needed LAT/LONG/DEPTH data in Excel ... but it is really only the LAT/LONG/DEPTH that I want.  I called Humminbird tech support and they said it is not available from their proprietary format.  I find this hard to believe as folks like Navionics certainly extract it.
Appreciate any help or links or suggestions on how I can extract this data from the Humminbird SONAR files for subsequent use.
Offline Rüdiger
Re: Extracting GPS & Depth from Humminbird SONAR files
« Reply #1 on: October 14, 2017, 04:47:02 AM »
Hi Mike
Welcome to the forum :)
Possibly this is possible with the help of the HumViewer software. Water depth and position data are  from the boat but not from the sonartarget.
mvh
Rüdiger
Finding is better than losing
Offline Nitro78
  • French frog
  • French frog!
  • Unit(s): Solix mega
  • Accessories: TM265 LH + 2 side imagin transdeucer an
« Reply #2 on: October 16, 2017, 12:05:57 AM »
You can use Reefmaster for that !
Offline ckd022
  • Unit(s): 798ci SI Combo
  • Software: 5.840
« Reply #3 on: October 17, 2017, 08:00:10 PM »
Humviewer will export lat/lon, date/time, depth, speed and heading to a csv file IF it can read the sonar files for your unit.  I have a 738SI that I have successfully done this with.  One caveat, if I remember correctly, csv export was broken in the latest release.  I believe you need version 67 for that feature to work.  If you need a copy, PM me and I'll send you the one I have.  I have gotten it to work with Win XP, Win7 and Win10 in the past.
Kevin
Last post August 09, 2009, 05:37:08 AM
Last post September 13, 2009, 11:39:21 AM
by Wall-E-Baiter
Last post September 11, 2009, 10:30:57 AM
Last post June 04, 2012, 08:31:34 AM
by kucai
by lajo1976
Last post February 10, 2015, 03:11:54 AM
by peterv6i
Last post January 17, 2019, 07:53:33 PM
Last post May 04, 2023, 12:19:45 AM
by Walter
