Author Topic: Bad Resolution  (Read 9312 times)
Offline jules2003
  • Unit(s): 898c SI
  • Software: 6.420
Bad Resolution
« on: July 24, 2010, 03:10:49 PM »
Last week i made a record file with my HB 898. When i wanted to look at the record with HumViewer i noticed, that my pictures had a bad resolution.
They donīt look so good like the  HumViewer pictures in the forum. http://sideimagingsoft.com/forums/Smileys/classic/sad.gif
I made the record with 800kHZ. Any ideas?
Regars Michael
Re: Bad Resolution
« Reply #1 on: July 24, 2010, 04:15:18 PM »
800 is for shallow depths and beter imaging. However on the external viewer such as humview you will get some washout. 455 will give a clearer picture.
You might try setting changes on both the unit and the viewer program.  (contrast, brightness)
chuck
Re: Bad Resolution
« Reply #2 on: July 24, 2010, 11:12:08 PM »
Also that green color pallette looks washed out.  You need a good contrasting color pallette. Like the Brown/Yellow or make your own.
Offline jules2003
  • Unit(s): 898c SI
  • Software: 6.420
Re: Bad Resolution
« Reply #3 on: July 25, 2010, 11:38:46 AM »
Thanks for the replies.
I will try other color palettes for a better result.
Michael
Offline Chiboo
  • SpearFishing
  • Unit(s): Solix 10 MSI+ G3
  • Software: 4.130
Re: Bad Resolution
« Reply #4 on: July 25, 2010, 12:21:02 PM »
Michael
What water temperature was at record?
What transparency?
If water blossomed or was strongly muddy on 800 quality of a picture can fall.
Offline jules2003
  • Unit(s): 898c SI
  • Software: 6.420
Re: Bad Resolution
« Reply #5 on: July 26, 2010, 01:16:34 PM »
The water temperature was 17 degrees.
Transparency at 10, and the ground a little bit muddy.
I made a new snapshot with the HumViever  in SI brown, brightness at 1,4 and contrast at 1,1. I think it looks better than before. The next record i will make in 455 kHz for a better result.
Michael
Last post March 18, 2010, 06:45:39 PM
Last post June 13, 2013, 11:01:54 AM
Last post January 29, 2014, 01:41:51 PM
by cats-n-craps
Last post December 18, 2013, 04:19:44 AM
Last post July 13, 2014, 06:16:40 PM
Last post December 04, 2014, 07:24:52 AM
by Koen Vandecauter
