Author Topic: low resolution playback  (Read 10221 times)
Offline mmikos
  • Unit(s): 899ci HD
  • Software: 7.2
  • Accessories: autochart pro, ipilot
« on: July 13, 2014, 09:17:26 AM »
when i playback recordings on my 899si HD unit, the screen resolution reverts to a very low and blocky resolution.  same files will playback fine in Humviewer or when initially recorded.  any thoughts on how to improve or what i might be doing wrong.  The recordings look like early video game resolution.  very blocky.
Offline sfw1960
  • Bringer Of The 'Bird
Re: low resolution playback
« Reply #1 on: July 13, 2014, 12:53:54 PM »
What version software are you running?
Offline mmikos
  • Unit(s): 899ci HD
  • Software: 7.2
« Reply #2 on: July 13, 2014, 03:07:44 PM »
ver 7.02
Offline sfw1960
« Reply #3 on: July 13, 2014, 05:01:52 PM »
We always recommend resetting back to defaults both before AND after an update, if you'd like you can go on your data card and take a shorter recording (file size) from the RECORD folder and I will see how it plays on my machines.
To be honest - I have not recorded any other than a simulator - since I have been having fun with the fish and the screen shots.
There are several files you'd need to make into a zip file like a "R00002" folder (has a .SON and a .IDX file in it), and a "R00002.DAT" on the main root of the card;  I think a "R00002.XML" was created using the SON2XTF converter... Don't recall - but any recording that has the same file name numberering should be included and I can see what I come up with on either the 998 or my own 899.
My emails is my username@TgmailDOTcom.
I can check one out if you like??
I usually use Hummviewer here on the PC so I'm not even sure it that's an issue here - I also use class 10 SDHC Cards for the speed - if you have any of the following type:
SD, SDHC and SDXC - please be warned the SDXC format isn't supported and the machines DON'T like it, and could cause issues.
LMK!!
Offline mmikos
  • Unit(s): 899ci HD
  • Software: 7.2
« Reply #4 on: July 13, 2014, 05:59:56 PM »
thanks for all the good information, I will certainly take heed.   I did find the problem.  If you are viewing a playback in any speed other than straight play i.e.  1/2 speed, 2x or 4x, it will pixelate the screen, giving it the effect of an old video game.  Normal speed plays in the definition of the original recording.  Once again, strictly a user problem (me)
thanks
mike
Offline sfw1960
« Reply #5 on: July 13, 2014, 06:16:40 PM »
COOL!
Glad you got it sorted and it's no problem.
If you ever run into a snag, I am usually around here, BBC or www.Michigan-Sportsman.com/forum
Give a shout any time!
Last post March 18, 2010, 06:45:39 PM
Last post July 26, 2010, 01:16:34 PM
by jules2003
Last post May 17, 2011, 10:42:29 AM
by blake711
Last post June 13, 2013, 11:01:54 AM
Last post January 29, 2014, 01:41:51 PM
by cats-n-craps
Last post December 18, 2013, 04:19:44 AM
Last post May 15, 2014, 03:46:33 PM
Last post December 04, 2014, 07:24:52 AM
by Koen Vandecauter
