Author Topic: Is Trolling Motor Interference Universal?  (Read 16912 times)
Offline hamholfarm
  • Unit(s): 798ci SI ordered - waiting for delivery
  • Software: Unknown
  • Accessories: MS M, XTM-9-SI-180-T, AS GR50
« on: June 09, 2010, 06:42:59 AM »
Hello,
   I am about to become a member of the Humminbird family by purchasing a 798ci. I have been reading up on the various topics here and I am concerned about the interference people are experiencing with their trolling motors and TM mounted transducers. Do all brands and models of TM’s cause interference? Should I go ahead and get the Humminbird “Trolling Motor Choke” now because I will need it, or wait to see what happens and maybe save some money? I have a Johnson bow mounted, foot controlled trolling motor. I don’t know the year or model as I can not find any markings. The boat and main motor were purchased in 1988, so maybe the trolling motor is also from 1988. I don’t know how many previous owners there where, or what they may have done/purchased. I bought the boat from a used car salesman who took it in on a trade, and he knew very little about the boat.
Thanks for the help,
Chip
bobcoy
  • Guest
Re: Is Trolling Motor Interference Universal?
« Reply #1 on: June 09, 2010, 08:29:10 AM »
Hi Chip, The interference is almost always from the trolling motors with Pulse Width Modulation. I doubt that vintage motor has it. If you are not using the same battery as your trolling motor you should be fine. Bob
Wayne P.
  • Guest
« Reply #2 on: June 09, 2010, 10:26:16 AM »
No, the OMC motors were not variable speed and are three speed on each voltage setting (12/24V). I had 4 of those motors and none of them produced sonar interference although didn't have a SI unit with them.
The worst offender from what I can find, is the Motor Guide pre-digital variable speed. I just happen to have one of those and the interference is only on the 455 khz SI  :(
« Reply #3 on: June 09, 2010, 10:57:21 AM »
The "save myself some money" statement should be clarified here.....
When you buy a HB unit...HB will stand by their product...and IF you have interference problems AFTER you purchase a HB unit...HB will send you the interference kit at no charge to make you a satisfied customer.....(at least they did for me)...
That's why HB rocks...they stand behind their product until you are satisfied.....
I would say wait on the interference kit and see what happens...then call HB "IF" you have interference problems....
Offline hamholfarm
  • Software: Unknown
« Reply #4 on: June 09, 2010, 05:00:24 PM »
Thanks for the fast replies.
Sounds like I will be fine.  Yes, the TR is an old 3 speed, and I do have it wired to it's own battery with wires going up the opposite side of the boat that the wires for the 798ci will go.
I ordered the 798ci Combo and accessories today.  Can't wait for the brown truck!
Thanks again guys!
Chip
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
« Reply #5 on: June 14, 2010, 05:30:55 PM »
I have a HB 997 on A Minnkota Maxium 52 lb.trust 24 volt older motor . I have no interference
so far.   Gary
Offline muskyhunter
« Reply #6 on: September 04, 2010, 02:01:08 PM »
Trolling motor interference can still occur.  I have recently attributed a vertical bar to appear on my 998 when the trolling motor in engaged.  The trolling motor is on a separate electrical circuit/batteries and the locator is connected to the starting battery.  The locator does have an inline choke on the power cable.  I suspect there is interference induced into the transducer cable from the motor at the junction where the transducer cable follows along side the trolling motor housing.
Offline Mark997
  • Unit(s): 997cNVB 998c
« Reply #7 on: September 26, 2010, 09:11:11 AM »
One other thing you should be aware of is you may need to get a transducer shield for transducer and the people at transducer shield also made a special bracket for me so it would mount to Evinrude trolling motor you dont have much room from the skag of trolling motor to the front of trolling motor.
Offline Jasta
  • Unit(s): 797SI, 997SI,
  • Software: 4_960 & 4_950
  • Accessories: Weathersense, Interlink
« Reply #8 on: April 23, 2012, 11:09:11 PM »
If you have trolling motor interference on your bow mounted side imaging unit, copy/paste the link below to your browser and follow the instructions.  If you still have it, contact Humminbird to purchase a trolling motor choke!
http://www.humminbird.com/FAQ.aspx?ContentId=1849
Offline Gattlin
  • Walking the shores of Galillee
  • Zebco 202 Musky hunters club:P
  • Unit(s): 898C SI & 858C Combo
  • Accessories: Lakemaster chips, Ethernet
« Reply #9 on: April 24, 2012, 12:01:35 AM »
12? 24? 36? Trolling motor bow left, and TM Jack right? Consoles demise when they run the TM power to the right. Are the bow power cables grounded in any way with the console circuitry? Recharging TM batteries from the outboard? Try a main engine engine disconnect who know:) Good Luck see yaz out thar:)
Just one last cast.
Last post July 27, 2012, 08:01:52 AM
by ZX225SK
Last post March 18, 2011, 06:27:53 AM
by SaminVa.
Last post March 30, 2013, 02:01:11 AM
by wolfs4evr
Last post April 09, 2013, 07:20:16 AM
Last post August 20, 2013, 04:08:30 PM
Last post June 12, 2017, 01:44:26 PM
by zip308
Last post April 15, 2019, 11:15:23 AM
by fishcall
Last post September 12, 2021, 08:18:44 PM
