Author Topic: Interlink help  (Read 15570 times)
Offline bigbassbuck
  • Unit(s): 998SI & 747c
  • Accessories: Interlink
Interlink help
« on: May 05, 2010, 10:10:05 PM »
I getting a unconnected gps signal out of my 747c,my 998SI is getting the gps signal fine,I plugged the 998 into slot #1 and the 747c into slot #2 then plugged the gps puck into the gps slot,what am I doing wrong,I checked the settings on the 998 so it says its interlinked,but the 747 say unconnected still
Offline nmanley
  • Boat Sig
  • Unit(s): 798c si, 898c si, Interlinked
  • Software: 4.510 & 4.880
  • Accessories: Y cable and thru hull xducer
Re: Interlink help
« Reply #1 on: May 06, 2010, 05:33:07 PM »
There are some connection drawing around that show a AS-YC cable used to keep the GPS antenna connected to the 998. Suppose to have better GPS refresh rates. I think it helps the disconnection problem too.
I think your 898 already comes with the "Y"cable. Mine did.
Someone else will chime in that knows for sure.
Found it....Lets see if this works....
« Last Edit: May 06, 2010, 05:47:31 PM by nmanley »
Re: Interlink help
« Reply #2 on: May 07, 2010, 04:14:22 PM »
Bigbassbuck,
What software version are you running in the 747 unit?  [Current version is 4.740].
Try connecting the 747 up to the 998’s cables but unplug the GPS Receiver from the Interlink first (the 747 cannot produce enough current to run the GR50 GPS Receiver that came with your 998 unit) and see if it shows the InterLink as connected.
Do you have a WeatherSense Barometer or know someone who does or that has the older GR16 GPS Receiver?  My fear here is that at some point you tried to power the InterLink and therefore the GR50 GPS Receiver with the 747 unit which caused the accessory bus circuitry to burn up.
Yes the AS-YC cable is packaged with the 998c Si unit and every sonar-GPS Combo unit that we make or have made.
Offline bigbassbuck
Re: Interlink help
« Reply #3 on: May 08, 2010, 02:51:51 PM »
My software on my 998 is 4.850 is that the old version,my software on my 747c is 3.940,,so what do I need to do??
Offline bigbassbuck
Re: Interlink help
« Reply #4 on: May 08, 2010, 05:22:00 PM »
There are some connection drawing around that show a AS-YC cable used to keep the GPS antenna connected to the 998. Suppose to have better GPS refresh rates. I think it helps the disconnection problem too.I think your 898 already comes with the "Y"cable. Mine did.
I tryed that and still no luck,,any other suggestions,,,how would I download new software into the 747c,,it has no SD card slot??
Re: Interlink help
« Reply #5 on: May 08, 2010, 09:56:12 PM »
You will have to get the PC Connect cable to update the 747.
Offline bigbassbuck
Re: Interlink help
« Reply #6 on: May 12, 2010, 11:29:34 PM »
Ok I got the 4.880 software into the 998,and got the 4.740 in the 747c and the interlink still isn't working???I set the gps from auto to interlink+gps neither setting worked so were do I go now,send the 747c back too humminbird?? its driving me crazy!!!!!!!!!!!!!!!!!!! >:D
Re: Interlink help
« Reply #7 on: May 13, 2010, 02:34:12 PM »
Did you ever try connecting the 747c to the 998’s cables but unplug the GPS Receiver first?  Look at the Accessory Test menu when you do this and see what it is showing for the InterLink (Connected or Unconnected).
Offline bigbassbuck
Re: Interlink help
« Reply #8 on: May 13, 2010, 08:08:09 PM »
I tried that and the 998 says connected,the 747c says unconnected,so is there something wrong with the 747c
Re: Interlink help
« Reply #9 on: May 14, 2010, 10:56:15 AM »
That’s what it sounds like.  With the 747 connected to a known good connection that leaves only the 747c unit itself as the possible cause.  My guess is as before that the accessory output circuitry got overloaded and failed.  This is why we do not recommend using the 747c in combination with the more power hungry GR50 GPS Receiver.
Offline bigbassbuck
Re: Interlink help
« Reply #10 on: May 14, 2010, 04:00:47 PM »
If I send it back and get it fixed will it burn up again,,,,,,whats another good unit thats like 747c to interlink with
Offline majflyboy
  • Unit(s): 998 and 788
  • Software: 4.85
  • Accessories: InterLink
Re: Interlink help
« Reply #11 on: May 14, 2010, 06:09:40 PM »
I have a 788 and 998.  They work very well together interlinked.
Re: Interlink help
« Reply #12 on: May 18, 2010, 12:44:07 PM »
The 788 is the only non-Si color unit that is anything like the 747c unit you have.  I think that you will like it better than the 747c as it has a few more features plus a nicer display as well.  It will also come with its own GPS Receiver so you could have each unit connected to its own GPS Receiver and yet still connected to the InterLink.
An option would be to have the 747c repaired and purchase an AS-GR16 GPS Receiver.  Connect the AS-YC cable that came with your 998 unit to the unit, GR50 you have now and the InterLink but wait to power it on.  Connect the GR16 GPS Receiver to the 747c unit using the AS-YC cable that will come with the GR16 and also connect it to the 747c unit and InterLink.  Power the 747c on and set the GPS Override Menu (found under the Nav menu tab) to the “External GPS” setting.  Power on the 998 unit and do the same.  Now both units will have the faster GPS refresh rate and the 747c will not be powering the GR50 GPS Receiver.
Last post December 12, 2011, 02:36:56 PM
Last post June 23, 2014, 12:47:05 PM
Last post September 23, 2014, 09:33:05 AM
Last post January 06, 2015, 05:21:27 PM
by 4d-rock
Last post December 30, 2015, 12:01:28 PM
by bobcoy
Last post February 09, 2016, 01:34:58 PM
Last post October 05, 2018, 06:12:17 PM
by Ed Knight
Last post February 04, 2020, 09:46:17 PM
