Author Topic: Interlink not seeing GPS or Interlink on Port 1  (Read 14169 times)
Offline jbaran1
  • Unit(s): 997c
  • Software: 4.260
« on: December 11, 2011, 12:52:29 AM »
I'm tyring to setup an Interlink between and 997c (5.840) and a 1198c (5.700) and neither unit sees the GPS and Interlink on Port 1, but both can see it on Port 2.
On the 997c I do have Interlink menu options when connected to port 2.  When I place the 1198c on Port 2, the unit shows the GPS and Interlink connected, but I have no Interlink menu options?
I'm not able to register my new 1198c to check for a newer 5.840 firmware versions at the current time.
I've deleted all my way points, routes, and tracks and connected to the Interlink but retained the data on the 997c which was suppose to send null characters to the Interlink (per a forum topic) but this did not clear up the issue.
I was prompted on the 997c to join and select how I want to connect, but never prompted on the 1198c to join.
Offline George
  • Software: Always up todate
Re: Interlink not seeing GPS or Interlink on Port 1
« Reply #1 on: December 11, 2011, 07:55:15 AM »
jbaran1
If you go to --->  http://www.humminbird.com/Support/ProductRegistration.aspx  <--- you can register your units, both units should be registered together and/or updated as you get new units.
Have not been able to find any updates later then your 5.700
George
« Last Edit: December 11, 2011, 07:59:12 AM by George »
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
« Reply #2 on: December 11, 2011, 05:16:03 PM »
Have you tried connecting the GPS to one of the units and sharing the GPS over interlnk?
« Reply #3 on: December 12, 2011, 02:36:56 PM »
jbaran1,
I’ve replied to your other two posts about this.
You have the most recent software for both your 997 and 1198 units.
Try what is listed here:
http://www.humminbird.com/FAQ.aspx?ContentId=3080
Last post April 27, 2010, 10:22:03 AM
Last post May 18, 2010, 12:44:07 PM
Last post October 12, 2010, 02:14:58 PM
Last post February 16, 2011, 10:54:41 AM
by Fishin
Last post March 03, 2011, 02:44:11 PM
Last post April 01, 2011, 11:44:30 AM
Last post May 11, 2011, 12:59:02 PM
Last post October 18, 2011, 04:42:36 PM
by Rocketman783
