Author Topic: Watching Recordings On TV  (Read 6047 times)
Offline Bayou Basser
  • Unit(s): Helix 5 Chirp DI GPS G3, Helix 7 Chirp M
  • Accessories: None
« on: February 11, 2021, 10:15:13 AM »
Is it possible to watch your recordings on a TV directly from your helix unit using an Ethernet to HDMI adapter?  This would bypass the use of Humviewer.
Bayou Basser
Re: Watching Recordings On TV
« Reply #1 on: February 11, 2021, 11:01:00 PM »
Interesting idea  ...
Try it and let us know  ... I don’t see how it could hurt anything in the unit  ...
  • Accessories: None
« Reply #2 on: February 11, 2021, 11:13:23 PM »
It will be a couple of weeks before I can.  In the mean time if someone else tries they can post results here.
Offline Rüdiger
« Reply #3 on: February 15, 2021, 03:17:12 AM »
Hi Bayou
It is easiest if you connect your laptop to the television and play your recordings using HumViever.
If your 899ci HD Si also has a direct TV connection, my 898 has one, so your recordings could be played.
mvh
Rüdiger
Finding is better than losing
  • Accessories: None
« Reply #4 on: February 15, 2021, 11:19:37 AM »
Hi Rudiger.  Yes I know, I've been watching recordings using a hdmi cable between laptop and tv for many years.  Just wondering if recordings might be sharper connecting 'bird directly to a high def tv.  It doesn't look like a Humminbird ethernet cable has the same connections as a computer or tv ethernet.  If it was you could use an ethernet to hdmi adapter.
Weather is crazy here.  Can you believe in West Monroe, Louisiana we have 5 inches of snow on the ground?
Bayou Basser.
Offline Rüdiger
« Reply #5 on: February 16, 2021, 03:57:52 AM »
Hi bayou bassist
I don't think there is any ready made device that converts the HB ethernet signal into a television readable signal.
The old devices had a direct video output with a corresponding cable and that gave a very good picture on the TV.
mvh
Rudiger
« Reply #6 on: February 16, 2021, 10:42:02 PM »
I think HB removed the Video Out capability in the xx9 series  ...
Last post May 22, 2012, 05:13:20 PM
Last post June 24, 2010, 05:52:52 PM
by pig75
Last post January 30, 2012, 08:15:19 PM
Last post April 08, 2012, 05:18:05 PM
by RickT
Last post January 20, 2014, 03:31:45 AM
by crankin007
Last post March 22, 2014, 03:15:22 AM
Last post March 25, 2014, 11:33:54 AM
Last post April 03, 2014, 11:22:45 AM
