Author Topic: cant see recordings made with my 798 si  (Read 10305 times)
Offline crankin007
  • Unit(s): 597, 798 HDSI
« on: January 18, 2014, 05:37:39 PM »
im having problems viewing my recordings made with my 798 si unit. If I go to snapshot and recording view I cant see my recordings . but I see them fine on the chart view screen where I can select them and even edit their name….any ideas what I’m doing wrong. Oh and I have the unit off the boat and in normal mode.
Re: cant see recordings made with my 798 si
« Reply #1 on: January 18, 2014, 06:16:34 PM »
When you were recording...did you manually "Stop" the recording in the Recording Xpress menu...??
Did you have a SD Card in the unit during recording...??
« Last Edit: January 18, 2014, 06:18:15 PM by rnvinc »
Offline crankin007
« Reply #2 on: January 18, 2014, 07:52:44 PM »
yes to both questions. i can see them on the the map....can scroll over to select edit move all that....just don't see them in the snap shot and record menu
« Reply #3 on: January 18, 2014, 10:17:10 PM »
Do you have the SD card in the unit?  Have you taken it out to download or anything?  Deleted any files?  You will be able to see the waypoints because those are stored on the unit, but the recordings are stored on the SD card.  If it IS in the slot, remove it and reinsert it.
Offline crankin007
« Reply #4 on: January 18, 2014, 11:00:11 PM »
maybe i should try a new recording. funny thing is when i take my sd card out i still see the recording icon on the map viewer? and yeah i did test the sd card out....it works
« Reply #5 on: January 18, 2014, 11:29:37 PM »
Yes, you will still see the icon.  When you start recording the unit creates a waypoint and uses the recording icon as the waypoint icon.  So it will remain even if you delete the recording or remove the sd card.
« Reply #6 on: January 19, 2014, 11:09:41 AM »
There have been some postings of the SD Card actually being "popped" out of its engagement when the card slot cover was snapped back in place...
Offline crankin007
« Reply #7 on: January 20, 2014, 03:31:45 AM »
hmmm ok i will try to make some new recordings.....didn't know that thanks man
Last post September 10, 2018, 08:02:14 PM
Last post June 27, 2010, 10:47:36 PM
by calli1
Last post August 11, 2010, 02:15:33 PM
by mendota
Last post August 30, 2010, 01:48:09 PM
Last post March 30, 2012, 04:37:41 PM
by alex
Last post May 10, 2013, 03:04:44 PM
by matt@reefmaster
Last post September 30, 2015, 09:14:15 AM
by CamoHunter
Last post May 06, 2017, 08:01:02 PM
by jachristensen3
