Author Topic: Helix 9 Chirp Mega DI GPS G3N ... view Autochart on Helix 7?  (Read 23986 times)
Offline MarjanK
  • Unit(s): 898c, Helix 7 DI G2
  • Software: ?
  • Accessories: GPS receiver
« on: August 04, 2020, 07:45:54 AM »
Hi,
I have a Helix 9 Chirp Mega DI GPS G3N and I intend to buy a Helix 7 Mega DI GPS G3N, which I would use mainly to display the position, so only as a GPS.
I want to connect the device to a network. In Helix 9 I have an Autochart Live. Will the data from the Autochart (which is as stated in Helix 9) also be visible on Helix 7?
What data can be shared between devices?
Which cable is needed to connect 2 devices?
Thanx,
Marjan
Re: Helix 9 Chirp Mega DI GPS G3N ... view Autochart on Helix 7?
« Reply #1 on: August 04, 2020, 10:10:56 PM »
Mapping of any kind cannot be shared between HELIX units  ...
It is possible to copy your AutoChart data to another Zero Line card to use in another unit  ...post that question in the AutoChart subforum here  ...
 http://forums.sideimagingsoft.com/index.php?board=76.0
To connect 2 HELIX units for sharing waypoints and Sonar you will need 2 AS EC QDE adapter cables
https://humminbird.johnsonoutdoors.com/accessories/cables/as-ec-qde-ethernet-adapter-cable
And you will need an Ethernet cable long enough to reach  ...
https://humminbird.johnsonoutdoors.com/accessories/cables?f%5B0%5D=field_product%253Afield_hbcabletype%3A27016
« Last Edit: August 04, 2020, 10:12:09 PM by rnvinc »
Offline MarjanK
  • Software: ?
« Reply #2 on: August 07, 2020, 01:31:07 AM »
Thanks, Rickie.
So it won’t be possible to see Autochart maps on Helix 7. Unfortunately, Helix7 only has one card slot.
One more question. Is it possible to read the length of the stored track or the length of the route we traveled (in miles)?
« Reply #3 on: August 07, 2020, 07:26:34 PM »
Thanks, Rickie.
The only way to see your (HELIX 9 created) AutoChart mapping on the HELIX 7 is to download the AutoChart data from the HELIX 9 to a Zero Line card and then you have 2 options  ...
1. Simply stick the Zero Line card into the HELIX 7 and the 7 will read and display it  ...
2. Copy the AutoChart data from one Zero Line card to another Zero Line card to have the AutoChart data available for both units  ...
To see distance traveled in a track  ...
*Change display under the Setup tab from “Overlays” to “Boxes”
*Then Change one of the boxes to Triplog in “Digital Readouts” under the Setup tab  ...
« Last Edit: August 07, 2020, 07:28:06 PM by rnvinc »
Offline MarjanK
  • Software: ?
« Reply #4 on: August 11, 2020, 12:54:56 AM »
Thank you,
This week I’m going to the sea and trying out track length settings.
As for Autochart on Helix 7 ... if I want to insert Zero lIne in 7 I have to throw out Navionics ... and then I'm out of navigation maps  :( , or?
br, Marjan
« Reply #5 on: August 11, 2020, 11:12:55 PM »
Thank you,
br, Marjan
Correct  ... HELIX 7 only has one card slot so you would have to remove your map card to insert a Zero Line card  ...
Last post April 18, 2017, 07:40:31 AM
by RivRunR
Last post April 26, 2018, 08:35:22 PM
Last post March 26, 2018, 09:48:08 PM
Last post April 16, 2019, 03:38:56 PM
by cat_in_the_hat
Last post September 23, 2019, 09:36:42 AM
by ezfishn
Last post March 14, 2020, 01:34:42 AM
Last post June 06, 2020, 09:52:35 PM
