Author Topic: help HELIX 9 CHIRP MEGA SI GPS G2N  (Read 31086 times)
Offline Apook89
  • Unit(s): Helix 9 chirp si GPS g2n
  • Accessories: Nessuno
« on: February 19, 2018, 05:53:33 AM »
Hi, I need some help. when I'm in shallow water I have problems with visualization both in the side and down vision. can someone help me? I own a HELIX 9X CHIRP SI GPS G2N transducer XM 9 20 MSI T. PLACE SOME PICTURES. I apologize for my english not perfect :)
Re: help HELIX 9 CHIRP MEGA SI GPS G2N
« Reply #1 on: February 19, 2018, 06:32:42 PM »
Have you tried Restore Defaults  ...??
Is there another unit running at the same time  ...??
Do you have any screenshots in deeper water  ...??
Offline fshndude
« Reply #2 on: February 20, 2018, 08:34:19 PM »
When I first had my Helix 9 mega I thought that I was smarter than the unit. Started making all kinds of adjustments, well I can say I thought that I just ruined my picture. I did a reset default and have left it a lone. The images I am getting are GGGGGREAT. But I did spend a lot of time just going around looking at the bottom.
Dave in Currituck,NC
« Reply #3 on: April 23, 2018, 10:27:44 PM »
Is there another Sonar unit on the vessel operating at the same time  ...??
Is there a trolling operating at the same time  ...??
Offline Apook89
« Reply #4 on: April 24, 2018, 08:08:43 AM »
hi, there's no other unit on board.
« Reply #5 on: April 24, 2018, 09:24:22 PM »
Some of the examples looks like some kind of electrical interference  ... and some don't  ...
Do you have access to someone that you could test their head unit on your xducer  ...??
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #6 on: April 25, 2018, 09:43:13 AM »
 In this image, ( first in group ), is the SI range set at 1 1/2 the depth?  If so, that might explain that image.
          Mike
  I can't move the image here, so this is the post I'm talking about.
« Reply #3 on: April 23, 2018, 03:46:41 AM »
QuoteModifyRemoveSplit Topic
hi, after several problems I managed to make some screens of the problem. Thank you. The Helix has also been reset, but the problem persists.
Thank you again
« Reply #7 on: April 25, 2018, 10:10:29 PM »
I'm thinking the xducer is bad  ...
Cross-testing with another head unit or xducer can verify  ...
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #8 on: April 25, 2018, 10:29:15 PM »
I'm sure you are more correct than my long shot guess.   The divide and conquer technique is a good choice.
      Mike
Offline Apook89
« Reply #9 on: April 26, 2018, 03:38:07 PM »
I reset the unit. disassembled the transducer and mounted in the test tank at home, but the problem persists. I also noticed that the transducer makes a slight noise, a light pop-up is normal? the 2d vision works well, but the side and down vision have the problems described. Help
« Reply #10 on: April 26, 2018, 08:35:22 PM »
If you do not have access to a other xducer to test - you will need to contact your Humminbird distributor or dealer  ...
You can also contact Humminbird in Eufaula Alabama here  ...
https://www.humminbird.com/Category/Company/Contact-Us/
Last post October 04, 2017, 06:33:17 PM
by Stumpy
Last post March 14, 2020, 01:34:42 AM
Last post June 06, 2020, 09:52:35 PM
Last post August 11, 2020, 11:12:55 PM
Last post April 14, 2022, 10:09:49 PM
Last post April 15, 2022, 09:46:26 PM
