Author Topic: Pinched/Severed Transducer Cable  (Read 5305 times)
Offline proskeeterman@comcast.net
  • Unit(s): 997c Nav Helix 7 Si G3
  • Software: 6.300
  • Accessories: None
« on: June 04, 2020, 09:06:35 PM »
Ok I have a major problem as of now. I have  Helix 7Si G3N on front w/a transducer mounted on my Ultrex. Today the transducer cable apparently got pinched and a couple of the wires were severed. I'm at odds as to how this happened, but that's a mute point cause it did. I'm afraid to ask this but is the cable repairable or am I totally screwed. My thanks to all that respond.
Re: Pinched/Severed Transducer Cable
« Reply #1 on: June 04, 2020, 10:57:37 PM »
I have repaired (or modified) dozens of transducer cables  ...
I never recommend repairing a transducer cable that’s below the water line  ...
If you decide to repair -:
*Strip enough of the cable sleeve to have plenty of shielding foil to wrap around the repair   ...
*Offset the individual splices to make the repair smaller  ...
*Use heat shrink on the individual wire splices and the collective of wires  ...
*Liquid tape over the entire repair is also a good idea  ...
  • Software: 6.300
  • Accessories: None
« Reply #2 on: June 05, 2020, 01:12:10 PM »
Thanks Rickie, the damage is def above the water line closer to the head. I also found a decent step by step video on you tube. It mirrors exactly what you were saying. I am going to attempt the repair with a friend of mine. Hope it works out, thanks again.
by Rickard
Last post April 09, 2012, 05:18:50 PM
by bobcoy
Last post June 17, 2014, 08:44:31 PM
by sblatt
Last post March 14, 2015, 10:27:53 AM
by DiveExplorer
Last post April 13, 2015, 08:34:36 AM
Last post November 23, 2018, 09:52:54 PM
by henz
