Author Topic: Solix white and black screen  (Read 14470 times)
Offline serj5150
  • Unit(s): solix, 997
« on: May 30, 2020, 08:29:11 PM »
Hello everyone, this is my first time posting an issue here my solix 12 started messing up earlier today and I could never get it to work I connect the power and all it shows is a mostly white screen with some black towards the buttons I have no idea what to do and have been searching the Forum and internet for any similar issues. Any help would be greatly appreciated.... I am trying to figure out how to put up some pictures
Re: Solix white and black screen
« Reply #1 on: May 30, 2020, 11:43:29 PM »
Some SOLIX issues (very power hungry animals) can be attributed to low power (low/bad battery)  or insufficient amperage (too small of wires)  ...
**Troubleshooting can be ...:
*Load testing the battery to determine battery health  ...
*Verifying wiring (at least 10gauge) direct from battery to SOLIX  ...
And of course Restore Defaults is an easy 1st troubleshooting step  ...
« Last Edit: May 30, 2020, 11:46:28 PM by rnvinc »
Offline serj5150
« Reply #2 on: June 07, 2020, 11:49:35 AM »
Thank you very much rnvinc ;D.... I will give these a shot it started working again but then it started doing the same thing when I was on the water :-[.... I will definitely keep you informed in case someone else has the same problem ;D ;D
Offline serj5150
« Reply #3 on: June 07, 2020, 12:20:55 PM »
« Reply #4 on: June 07, 2020, 09:25:43 PM »
Did you verify a healthy battery and large enough wire to supply adequate amperage  ...??
Offline serj5150
« Reply #5 on: June 08, 2020, 03:04:36 AM »
Rickie I have not...but it's in the works for the week..but just to get the right, I am adding a thicker wire to the end of my humminbird power cord thin wire?
« Last Edit: June 08, 2020, 11:05:38 PM by rnvinc »
« Reply #6 on: June 08, 2020, 11:06:04 PM »
Correct .. the HB power cable is adequate for the “end of the run” (even tho I cut it down to about 2ft)  ...
I use 10guage marine tinned multistrand  ...
http://www.bestboatwire.com/marine-wire/flat-duplex-dc-boat-wire
Last post June 23, 2010, 04:55:41 PM
Last post May 26, 2011, 11:54:44 AM
by jazzybean
Last post July 01, 2011, 03:22:10 PM
Last post April 13, 2012, 09:43:46 AM
Last post January 29, 2015, 03:06:47 PM
Last post June 10, 2015, 04:27:29 AM
by navionic
Last post September 23, 2016, 07:07:39 PM
by etmci
Last post May 01, 2017, 02:45:38 PM
by N9Phil
