Author Topic: 798ci HD SI - white screen  (Read 13153 times)
Offline fishwalton
  • Unit(s): 798 ci SI HD Combo
« on: January 28, 2015, 05:32:26 PM »
GPS is working.  Screen for sonar is whilte blank. No images of any kind.  Turned unit on and off several times and removed it from mount and reinstalled a few times.  This did not help.  All I can see in sonar mode is a white screen.
What is the likely problem.   Any help will be appreciated.
Re: 798ci HD SI - white screen
« Reply #1 on: January 28, 2015, 06:11:47 PM »
Possibly bad transducer.  how old is the unit.  has the cable been cut or smashed. check connectors. Is the transducer cracked or broken.  Check power supply for  good charge...Can you swap any parts with any one else...
Offline fishwalton
« Reply #2 on: January 28, 2015, 07:27:29 PM »
The 798 is almost 3 years old. The transducer about 6 months old.  I have a 688ci HD DI on bow, so moved the 798 up there and got the same results. Even though the transducer was different there might have been something to see. But, same white screen.
« Reply #3 on: January 28, 2015, 08:53:42 PM »
Are you testing with the boat in the water ...??
Are you getting the same white screen for SI, DI and 2d ...??
Offline fishwalton
« Reply #4 on: January 28, 2015, 09:36:18 PM »
Yes to both questions.  Tomorrow I'm going to try my 798 on another boat that had a 798 and see what happens.
« Reply #5 on: January 29, 2015, 03:06:47 PM »
Its a long shot but try resetting the menus back to the factory defaults when you test it on the other boat.
Last post July 01, 2011, 03:22:10 PM
Last post February 06, 2012, 02:16:30 PM
Last post April 13, 2012, 09:43:46 AM
Last post May 07, 2014, 04:19:48 AM
by Tr-196
Last post January 25, 2015, 02:08:48 PM
Last post June 18, 2015, 10:11:28 PM
Last post May 01, 2017, 02:45:38 PM
by N9Phil
Last post June 08, 2020, 11:06:04 PM
