Author Topic: Helix 10 MSI+ G3N- will not power off (loop cycle)  (Read 8448 times)
Offline smallie690vs
  • Unit(s): Helix 10 & 12 MSI+ G3N
  • Software: v2.18 on both
« on: May 02, 2020, 07:40:47 PM »
just finished installation of new Helix 10 MSI+ G3N unit on the bow.
upgraded latest OS software to V2.18
unit is powered directly to 12V main battery.
(both power and ground wires)
weird problem - unit will not power off using the soft key (hold down button to power OFF).  the shutdown screen does appear, but then restarts to ON mode.  does this repeatedly forever.  only way to physically power OFF the unit is to unplug the main cable connector.
unit still did this before upgrading the software (original out of box).
anyone have any ideas on how to fix?
Re: Helix 10 MSI+ G3N- will not power off (loop cycle)
« Reply #1 on: May 03, 2020, 06:11:57 PM »
Try this  ...:
*Remove any map cards - test
*Export Nav data to a blank SD Card -  verify in HBPC that the Nav data is safely present
*Format Nav Directories under the Setup tab - test
« Reply #2 on: May 03, 2020, 06:28:51 PM »
just tried the procedure.
no nav data to backup (new unit - shared waypoints on other Helix 12)
menu...setup...reset nav directories...yes
power OFF still doesn't work (does not physically power off).
shut down screen appears, but then powers ON again.
loop
« Reply #3 on: May 04, 2020, 09:08:54 PM »
You will need to call HB on the loop issue  ...
1-800-633-1468
Last post April 30, 2012, 01:49:49 PM
Last post June 04, 2014, 09:30:02 PM
by rpro
Last post January 09, 2016, 11:02:20 PM
Last post July 23, 2016, 04:47:26 PM
Last post August 12, 2019, 11:55:10 PM
by Jamykid
Last post August 06, 2019, 08:31:22 PM
Last post September 18, 2019, 10:47:44 PM
Last post October 28, 2022, 09:28:47 PM
