Author Topic: 999ci hd loop reboot  (Read 16081 times)
Offline vRacj
  • Unit(s): 999CI HD
  • Software: 7.790
  • Accessories: default sensor
« on: September 10, 2019, 10:31:47 AM »
Hello,
I upgraded the Humminbird 999ci HD to the latest version (7.790).
After starting and loading, the Menu appears (Normal mode, Simulation mode, Information), after selecting an item, after ~ 2 seconds it restarts.
I am trying to run it without an SD card or from an SD card.
Power 12V, 0.87A
What can be done to make it work?
Re: 999ci hd loop reboot
« Reply #1 on: September 11, 2019, 12:24:35 AM »
Some have had success backloading older software by inserting an SD card with older software when the Navigation warning screen shows  ...
Our download section here doesn't have any versions for the 999  ...
You may be able to obtain older software from Humminbird 1-800-633-1468
Offline ezfishn
« Reply #2 on: September 15, 2019, 04:06:51 PM »
When you updated, was the unit networked with other units or accessories?
Offline vRacj
  • Unit(s): 999CI HD
  • Software: 7.790
« Reply #3 on: September 16, 2019, 08:46:15 AM »
No, HB is used without network, was updated without accessories.
I received firmware v7.650, but she did not help me(now can automatical run demo mode, other mode from menu leads to reboot). I maked request to v6.X, now waiting response
« Last Edit: September 16, 2019, 08:51:59 AM by vRacj »
« Reply #4 on: September 16, 2019, 09:51:17 PM »
Now that you can run the unit in Simulation  ...:
Format Nav Directories under the Setup tab to clear a possible corrupt Waypoint  ...
And Restore Defaults under the Setup tab also  ...
Offline vRacj
  • Unit(s): 999CI HD
  • Software: 7.790
« Reply #5 on: September 17, 2019, 08:05:30 AM »
I'm did this in firstly
« Reply #6 on: September 17, 2019, 08:55:56 PM »
While waiting for Humminbird response you might also post here to see if someone has an older version for your 999  ...
http://www.bbcboards.net/forumdisplay.php?f=133
Offline vRacj
  • Unit(s): 999CI HD
  • Software: 7.790
« Reply #7 on: September 18, 2019, 04:19:29 PM »
I maked downgrade HB, but this not help me.
What other solutions could there be?
Offline vRacj
  • Unit(s): 999CI HD
  • Software: 7.790
« Reply #8 on: September 18, 2019, 04:23:07 PM »
999ciHD_SI.6.900.bin         https://www.sendspace.com/file/2vtprv
999ciHD_SI_v7_650.bin      https://www.sendspace.com/file/h234x8
« Reply #9 on: September 18, 2019, 10:47:44 PM »
If downgrading software is not fixing the issue - sending the unit to Humminbird may be the only remedy left  ...
Last post April 30, 2012, 01:49:49 PM
by ITGEEK
Last post May 21, 2012, 07:36:48 PM
by C. Corner
Last post May 27, 2014, 01:28:23 AM
Last post June 04, 2014, 09:30:02 PM
by rpro
Last post March 25, 2015, 02:13:54 PM
by mako9man2
Last post June 27, 2016, 08:49:01 AM
Last post May 04, 2020, 09:08:54 PM
Last post October 28, 2022, 09:28:47 PM
