Author Topic: is a 200m Cat7a cable possible?  (Read 15209 times)
Offline babafeit
  • Unit(s): onix 10 si
« on: January 07, 2020, 03:24:30 PM »
Hi all,
I think that the typical limitation of Cat 7a cable without some sort of booster is around 100m. I own a Onix 10ci SI and I am trying to build a towfish to side scan in lake/ocean with depth between 200m and 250m. The aim is to locate shipwrecks.
I was wondering if any of you had tried a 200m or 300m cable and what kind of attenuation on signals/noise was present?  Was is usable?
Thanks.
Offline Rüdiger
Re: is a 200m Cat7a cable possible?
« Reply #1 on: January 08, 2020, 05:25:16 AM »
Hi babafeit
Welcome to the forum
Nothing is known to me over 100m, you have to try that yourself. However, you should also seal the cable entry on the transducer when used at such a great depth, there have already been problems. You should also consider the tensile load with such a large cable length.
Please continue to report on your project here.
mvh
Rüdiger
Finding is better than losing
Offline Chris_NSB
  • Unit(s): 798ci si and Helix 9 MEGA Gen 2
  • Software: latest
  • Accessories: Heading sensor & through hall transducer
« Reply #2 on: January 09, 2021, 10:29:45 PM »
It should be possible with the correct cable. Not sure if CAT7A is it or not but on this site https://www.edimax.com/landing/long_range_poe_solutions/en/ it does show a PoE range of 100m extended out to 200m. I'm thinking that is just from voltage drop. I'm guessing that is going to the same problem with the transducer cable. There are other ways to prevent voltage drop. You could use a cable that has a heavier gauge wire. I would test it on an extension cable before destroying your transducer cable.
Offline Rüdiger
« Reply #3 on: January 10, 2021, 06:09:52 AM »
Hi Chris
With very long cables, the ohmic resistance and the associated voltage loss become a problem.
But maybe you will find something here:
https://www.novasub.com/product-categorie/cables/video-data-cables/
mvh
Rüdiger
Last post June 28, 2014, 08:39:09 PM
by jrapose
Last post July 13, 2013, 06:51:56 AM
Last post March 05, 2012, 12:46:10 PM
Last post July 05, 2012, 03:16:10 AM
by Rüdiger
Last post September 11, 2012, 07:30:05 AM
by gros21
Last post November 16, 2012, 02:23:21 PM
Last post November 03, 2014, 09:41:00 PM
Last post March 05, 2019, 08:35:53 AM
