Author Topic: 999ci SI KVD COMBO  (Read 9934 times)
Offline SkippinLures
  • Unit(s): 999ci SI KVD & 587ci
999ci SI KVD COMBO
« on: May 26, 2014, 10:43:51 AM »
Hello all,
This just showed up at my door and I can't wait to install it. I'm sure I'll have questions so thanks in advance for all the help
Re: 999ci SI KVD COMBO
« Reply #1 on: May 26, 2014, 10:49:09 AM »
Here is where I'm planning on mounting the transducer. Right where the old one is. Thoughts?
« Reply #2 on: May 26, 2014, 10:57:13 AM »
Here is another view
« Reply #3 on: May 27, 2014, 01:28:23 AM »
You may have some left SI blockage with the drain plug and the livewell screen...
You might want to test with double sticky tape before drilling holes...(just be sure it's stuck good)...
Some have modified their drain plug and/or livewell screens to eliminate blockage problems...
Some have installed a backer board as a spacer between the transom and the HDSI....
You also may need to think about the AS SIDB Y cable setup with a shoot thru 2d xducer so the HDSI wouldn't have to be mounted below the boat hull where it could possibly be damaged by waterborn debri...
I would suggest your idea of mounting first...and then deal with issues "if" they arise...
« Last Edit: May 27, 2014, 01:30:12 AM by rnvinc »
Last post February 09, 2014, 01:13:24 AM
Last post February 14, 2014, 12:57:39 PM
Last post April 04, 2014, 11:34:17 PM
Last post May 28, 2014, 08:20:10 AM
Last post August 11, 2015, 08:11:09 AM
by bote
Last post January 28, 2016, 10:04:53 PM
Last post June 27, 2016, 08:49:01 AM
Last post September 27, 2022, 06:22:03 PM
