Author Topic: network issues  (Read 14456 times)
Offline locoengineer
  • Unit(s): 788 and 899
  • Accessories: I Pilot
network issues
« on: February 15, 2015, 04:35:34 PM »
I have a 788ci HD DI on the bow, A 899 ci HD SI on the console , and IPILOT Link all hooked to a 5 port Ethernet switch and cannot get the network tabs to come up on either unit. Also it does not show the IPILOT connected. Any ideas?
Re: network issues
« Reply #1 on: February 15, 2015, 07:45:02 PM »
Are you sure the switch is powered correctly?
Maybe try connecting the 2 units directly to each other and see what you get .... and go from there.
Re: network issues
« Reply #2 on: February 15, 2015, 08:44:45 PM »
When I first turned them on, I had the network tab come up on the 788 and even named the unit. Then after that I lost it. I have not checked the power supply yet that was my next move. The other issue is my I Pilot link does not show connected on the 788.
Re: network issues
« Reply #3 on: February 15, 2015, 08:58:51 PM »
Are they all connected thru the 5 port switch?  That would be a common point, if it wasn't working none of your networking would work..... Isolate by connecting direct and bypassing the switch.
Re: network issues
« Reply #4 on: February 15, 2015, 09:55:42 PM »
I'll try that, I checked the power to the 5 port switch as you suggested and I think that could be the problem. It would be nice if they had a power light on them so you could tell if you had power. Thanks for the help.
by fishinphil
Last post April 08, 2013, 10:27:53 AM
Last post July 12, 2013, 09:07:35 PM
by tgordon
Last post December 30, 2013, 08:47:55 PM
by Rotus623
Last post May 12, 2014, 02:32:00 PM
Last post July 14, 2014, 09:49:17 AM
Last post September 09, 2014, 09:34:33 AM
Last post February 26, 2015, 12:45:14 PM
