Author Topic: 898 To Computer Question  (Read 6130 times)
Offline alumabass
  • Unit(s): 898 SI and 525
« on: April 02, 2010, 03:43:29 PM »
I ordered my SanDisk Extreme III 4 gb card from Amazon, but a couple of questions about accessories to make all of this work with my PC.  I have not dug in the box yet, so I do not know if these are included, and I want to double check that I need them:
http://store.humminbird.com/products/323059/AS_CR
http://store.humminbird.com/products/323024/AS_PC2
Thanks-Arlo
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
Re: 898 To Computer Question
« Reply #1 on: April 02, 2010, 04:40:46 PM »
Arlo,
your ScanDisc Extreme III 4 GB card is a High Capacity card everything bigger than 2 GB is High Capacity (HC)).
So the Humminbird Card reader you're referring to will NOT work with it. Go the next electronics or PC shop and get a SD card reader that is capable to handle your card. They aren't a lot more expensive than the regular (old) SD card readers.
As for the AS-PS connection kit:
You will need the AS-PC cable from Humminbird to connect the unit to the computer, but the power source wiring that comes with the AS-PC connection kit might not be sufficient for powering up your unit for an extended time.
You better cut off the battery holder and connect the wires to a decently loaded and working 12V car or motorcycle battery. Don't forget to put an 3 Amp in line fuse into the plus (red) wire. You'll be in a world of trouble if you're updating your unit and the update is interrupted due to a power loss during the update.
If your PC doesn't have an RS 232 (9 pin) / serial port but USB ports only you'll need a RS 232/USB adapter.
You can get them at PC shops as well or you can get the Humminbird one:
http://store.humminbird.com/products/322963/AS_USB
Hope this helps and good luck
Regards / Harry
YES,......
WE SCAN!
Last post January 18, 2012, 05:01:22 PM
by havingfun2
Last post May 06, 2012, 09:33:25 AM
Last post March 22, 2013, 05:59:11 AM
by chuckauten
Last post March 26, 2013, 09:17:06 PM
Last post February 19, 2014, 09:20:57 AM
by N9Phil
Last post December 26, 2013, 01:49:58 PM
Last post January 07, 2014, 12:07:26 AM
by 1fireball
Last post November 04, 2014, 03:56:23 PM
by JordanLimit
