Author Topic: Help Adjusting transducer angle on my 899 di hd transducer  (Read 27073 times)
Offline txpartyguy
  • Unit(s): 899 hd si
« on: April 30, 2014, 11:59:23 PM »
 ::) Can anyone tell me if the high def transducer has a angle adjustment I know you can move up and down I added a spring back bracket i have leveled the boat on trailer front to back and sideways then i have leveled the bottom of  transducer and on both sides of bracket  i have added pics to see my install please let me know your thoughts this is on a 2010 bass tracker TX175
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
Re: Help Adjusting transducer angle on my 899 di hd transducer
« Reply #1 on: May 01, 2014, 12:15:28 AM »
Your install appears off to a good start. Your next step is to see what your on the water results are. One common adjustment that you may
need will be to lower the back of the transducer about 1/4". This often will improve 2D readings at higher speed. Test first. It may be OK where you are.
                Mike
Offline txpartyguy
« Reply #2 on: May 01, 2014, 12:21:58 AM »
I bought the transducer saver spring back bracket which gives it no movement to tilt up or down just wondering if it was built to where it don't have that adjustment just wondering if anyone else had this bracket and how they set it up i guess only a water test will show ...and using the level is that the correct way to set it up ...Thanks to all replays I'm new here
« Last Edit: May 01, 2014, 12:26:34 AM by txpartyguy »
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #3 on: May 01, 2014, 12:28:36 AM »
Do you have the SBB-4 spring back bracket?
Offline txpartyguy
« Reply #4 on: May 01, 2014, 12:37:10 AM »
yes and there is a block that you use to keep the transducer from moving
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #5 on: May 01, 2014, 12:47:28 AM »
I just looked over the install instructions and can't see how to make the adjustment you need. Try calling Transducer Shield & Saver.
I've had good results working with them. Good luck.
         Mike
« Reply #6 on: May 01, 2014, 12:06:33 PM »
I didn’t see any install directions but it looks to me like you would install the block after you get your transducer mounted and tested.  That way you will the transducer at the angle you need before installing the block and locking it in place.
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
« Reply #7 on: May 02, 2014, 08:09:36 PM »
What transducer is that? Your profile says 899 hd si. Question is about  DI. Looks like HDSI ducer. This has a 5 degree adjustment. Unfortunately it is Big $$
Item # SBB-HDSI-COMBO is our latest and greatest solution for installing Humminbird's® big Side Image Transducer on the transom.
« Last Edit: May 02, 2014, 08:41:17 PM by bobcoy »
by Sonshine Fishing
Last post March 16, 2010, 04:53:21 PM
Last post March 16, 2010, 03:00:25 PM
by Brian37075
Last post February 21, 2013, 08:56:17 AM
Last post May 14, 2013, 11:57:41 AM
by LittleGazoo
Last post March 04, 2015, 10:17:35 PM
Last post July 16, 2018, 09:27:05 PM
