Author Topic: How to network two helix mega units 1 SI and 1 DI  (Read 12653 times)
Offline Paul Landon
  • Unit(s): Helix 9 si mega gn, Helix 10 di mega gn2
  • Software: 1.840
« on: March 26, 2018, 07:32:36 PM »
I have a Helix 9 Mega SI G2N and on getting a Helix 10 Mega DI G2N. Can I use the Mega 9 SI (XM 9 20 MSI T) transducer on a Mega 10 DI and if so how do I connect it? I would also like to install a transducer on the Minn Kota Power Drive to be able to switch at least one unit to.
Re: How to network two helix mega units 1 SI and 1 DI
« Reply #1 on: March 26, 2018, 09:40:37 PM »
Each unit's stock xducer will need to be connected to its own head unit  ...
Then you can Ethernet the units together to select which xducer you want each data coming from  ...in each unit's Ethernet Menu  ...
Here is the Ethernet manual pdf  ...:
https://www.humminbird.com/WorkArea/DownloadAsset.aspx?id=3047
Here are the available lengths of Ethernet cables  ...
https://www.humminbird.com/productCategory.aspx?id=3774&facets=7319,
You will also need an Ethernet adapter cable for each HELIX  ...
https://www.humminbird.com/productDetail-Accessory.aspx?Pageid=728&id=868
Are you wanting either MEGA xducer on the trolling motor  ...or only 2d data  ...??
Last post September 09, 2014, 09:34:33 AM
Last post April 20, 2017, 10:00:11 PM
Last post October 06, 2017, 04:52:06 PM
Last post November 22, 2017, 09:10:21 PM
Last post February 19, 2018, 08:24:42 PM
by Whistler
Last post March 26, 2018, 09:48:08 PM
Last post June 20, 2018, 06:19:41 AM
by Dusty-Pants
Last post April 15, 2020, 09:51:39 AM
by bglures
