Author Topic: Connecting 1kW Airmar transducer: power at 200kHz still 500W ?  (Read 11144 times)
Offline barfoot
  • Unit(s): 898HD
Hi folks.
Sorry for my bad english.....
Since a few years I'm happy with my 898c HD SI which I use only in 2D-mode.
I fish in the ocean between 100-400 ft of water. Makes no sense with DI or SI......
I wanted to improve my 200kHz signal with a transducer from Airmar. TM-260 or TM-270.
As I saw in the specs it look's like my unit is capable of an output power of 1'000W RMS.
I was wondering, why I don't "burn" the Airmar P79 (600W) when I using it with my 1kW-unit since years.
Otherwise on Furuno units, you can change our output-power (600W, 1kW, 2kW..).
Today I found this post:
http://forums.sideimagingsoft.com/index.php?topic=7486.msg44990#msg44990
Quote from Greg:
"The 898 units are a 1'000 watts RMS sonar unit but only when using an optional 50kHz transducer.  When using the 200/83kHz frequencies they are a 500 watt RMS unit."
I NEVER saw a note in the manual, that this unit only supports 1kW only at 50kHz.
But I suspect this is a fact and if so, it makes no sense to upgrade my unit with such an expensive transducer.
Can anybody confirm, that it's not possible to gain the signal at 200kHz from 500w to 1Kw?
And if so this is only a further confirmation, that this brand is generally more made for lakes than for the ocean.....
Thanky you for any advise.
Martin
Re: Connecting 1kW Airmar transducer: power at 200kHz still 500W ?
« Reply #1 on: March 21, 2018, 10:54:01 AM »
Greg doesn't visit here much any more .... but if he made a statement about something Humminbird you can take it to the bank.  I really miss his postings even though Rickie has stepped up and is a good resource also.
« Reply #2 on: March 21, 2018, 07:47:00 PM »
Here is part of the specs for the 898  ...
Notice the asterisk (*) at the 50*kHz and the 1000Watts*  ...
https://www.humminbird.com/Products/898c-SI-Combo/
« Last Edit: March 21, 2018, 07:48:26 PM by rnvinc »
« Reply #3 on: March 21, 2018, 07:49:26 PM »
And I totally agree with Bob -
If Greg said it - it is true  ...
Offline barfoot
  • Unit(s): 898HD
« Reply #4 on: March 22, 2018, 04:03:54 AM »
Thank you guys.
I never noticed this  *
 >:D
Really bad this kind of "marketing".....
And on the other side it's a really strange konfiguration that you power up a 200 kHz element with 500w and only the 50 kHz element will get 1 kW. I never noticed this konfiguration by other companies.....
I think it was a cheap solution that they can list a power output of 1'000 w.
So it makes really no sense to invest more money in an Airmar 260 transducer with this unit....
Martin
Last post August 28, 2012, 04:31:21 PM
by truk
Last post December 06, 2012, 12:44:14 PM
Last post April 08, 2013, 01:29:07 PM
by Warrior12934
Last post February 16, 2016, 09:43:04 PM
Last post March 11, 2016, 11:05:35 PM
Last post November 01, 2016, 08:07:45 PM
Last post October 27, 2019, 04:49:01 AM
by reso
Last post June 02, 2023, 09:14:12 AM
by kpkyllo
