Author Topic: to see left side imaging sides on one screen and right on another  (Read 15297 times)
Offline danlaboucane
  • Unit(s): ,798 hd onix8 ct , solix 12 msi
  • Software: 7.6 ,3.03
  • Accessories: sm3000+eth 5 port to get SI on onix CT,
how to see left side imaging side on one screen and right on another ? do i need two transducers ? each connected to different units or can i share a different side of the SI by ethernet ?
Re: to see left side imaging sides on one screen and right on another
« Reply #1 on: December 03, 2017, 10:01:24 AM »
The only SI/SI Combo view available is the stacked SI view as seen below with version 1.350 in HELIX series  ...(Not sure the version number in ONIX or SOLIX)  ...
This view can be created with both left SI data and right SI data coming from the same SI xducer  ...
Or from 2 SI xducers using the AS SILR Y cable for HELIX G1 series  ...
https://www.humminbird.com/productDetail-Accessory.aspx?Pageid=728&id=977
Or from 2 SI xducers using the SM SILR Y Cable for HELIX MEGA series  ...
https://www.humminbird.com/Products/SM-SILRY/
Or from 2 SI xducers using the AS 14 SILR Y Cable for ONIX series  ...
https://www.humminbird.com/productDetail-Accessory.aspx?Pageid=728&id=3321
Or from 2 SI xducers using the SM SILR Y Cable for SOLIX series  ...
Left SI data and right SI data cannot be shared separately thru Ethernet  ...
« Last Edit: December 03, 2017, 10:10:11 AM by rnvinc »
« Reply #2 on: December 03, 2017, 10:46:58 AM »
but if i use two onix SI units connected to two different transducers can i choose to display right side on right screen and left  side on the left screen ? and still be ethernet connected ? i would use that when trolling and bring a unit on the bow when casting .
« Reply #3 on: December 03, 2017, 10:53:25 AM »
I'm afraid not  ... Sharing SI thru Ethernet specifies SI from "Unit 1" or SI from "Unit 2"  ... which, in effect, requires sharing "left SI data and right SI data"..
There is no selection choice to share "left SI data or right SI data"  ...
« Last Edit: December 03, 2017, 11:18:43 AM by rnvinc »
« Reply #4 on: December 03, 2017, 11:44:07 AM »
ok thanks rickie, but i would still be able to isolate right and left on the two units at console ?
« Reply #5 on: December 04, 2017, 09:44:39 PM »
Correct  ... And probably a better option anyway so that left SI can be full screen on the left unit and right SI could be full screen on the right unit  ...
Last post April 16, 2012, 10:48:52 PM
by Shooter00
Last post September 14, 2012, 04:27:47 PM
by gros21
Last post March 14, 2013, 04:37:52 PM
by Rickard
Last post February 27, 2014, 08:35:33 PM
by Rotus623
Last post March 22, 2015, 01:10:07 AM
by vik33
Last post June 08, 2015, 04:45:38 AM
by vik33
Last post June 21, 2016, 11:33:31 AM
Last post September 07, 2020, 09:33:15 PM
