Author Topic: During loading recording data into Humviewer, some error occurs.  (Read 35534 times)
Offline Mc Cloud
  • do you think that is the air, you're breathing now
  • Unit(s): Helix 10 mega si
  • Software: 1.350
  • Accessories: AS GPS HS
« on: September 18, 2017, 04:50:46 AM »
I tried to check the recording data in Hum Viewer.
When I open the recording file with Hum Viewer, it seems ok
Loading B000.SON
Loading B001.SON
Loading B002.SON
Loading B003.SON
But, at the turn of B004.SON, error occurs.
"This is not a valid Humminbird Sonar recording file.
 Cannot find type for file : B004.SON"
Has anyone experience this error?
My device is Helix10 Mega SI G2N.
Re: During loading recording data into Humviewer, some error occurs.
« Reply #1 on: September 18, 2017, 09:39:29 AM »
Please find the actual recording folder on your PC  ... It should be listed as something like "R000x" and located in the "RECORD" folder on the SD card that was in the HB unit when the Recording was made  ...
Please list the files located in the "R000x" folder  ... and list the kb size of each file  ...
I think the B0004.SON is the GPS data from the Recording and maybe it is corrupt somehow  ...
Offline ckd022
  • Unit(s): 798ci SI Combo
  • Software: 5.840
« Reply #2 on: September 18, 2017, 08:26:16 PM »
When I was decoding the SON files back in the day (I have a 798ci SI Combo), I only ever saw 3 SON files: B000 was the 50/83khz, B001 was the 200khz, B002 was the Port SI, B003 was the Starboard SI.  Maybe B004 is the Down Image?  If it is, I didn't have down imaging so I would have never run across that particular file.
If B004 seems corrupted, try renaming the B004.IDX and B004.SON files to TEMP.IDX and TEMP.SON then re-loading the DAT file.  I'm guessing that Humviewer will just start after loading B000 through B003, but you will lose whatever imaging data was stored in B004.
Kevin
Offline Mc Cloud
  • Software: 1.350
« Reply #3 on: September 19, 2017, 04:18:11 AM »
Kevin
Thank for your help.
I removed the B004, No error occurs.
The B004 is not for DI, I can get DI replay.
Thx.
« Reply #4 on: September 19, 2017, 09:38:29 AM »
Thx.
The HB core series units do not have a dedicated DI channel transmitting to a DI piezo in the SI xducer  ...
The DI image is computer generated from the SI data into a format that "looks" like DI  ...
Therefore, there will be no SON file for DI (in the HB core series SI units)  ...
Offline ckd022
  • Software: 5.840
« Reply #5 on: September 19, 2017, 10:37:13 AM »
Rickie,
I knew that was the case with my 798, I just wasn't aware of the capabilities of the new Helix units.  It has been such a long time since I looked at this, but I think I already knew if you have a DI unit, then the B002 file is the down imaging data.
In fact, I don't believe Humviewer "creates" the down image from the two SI images the way the sonar units do, it just takes the data in B002 "rotates it" to look like down imaging, and if you have an SI unit, it displays the port SI data as the DI image.
It would be interesting to know what is stored in the B004 file and even to see one.  I wonder if they changed the format of the completely or if they just gave it a different header to differentiate it from the older file types.  Humviewer hasn't been updated in such a long time I can see where it might not understand some of the newer sonar files that the new sonar units are creating now.
Kevin
Offline Mc Cloud
  • Software: 1.350
« Reply #6 on: September 19, 2017, 08:25:56 PM »
For HDSI tranducer, you are right, there is no dedicated or physical channel for DI in Xducer.
But in MegaSI Xducer, there is physical DI channel.
( I have picture MEGA SI Xducer disassembled, but I don't know how to upload )
Following link is some Korean HB community, there is MEGASI Xducer which is disassembled.
« Last Edit: September 19, 2017, 08:29:23 PM by Mc Cloud »
« Reply #7 on: September 20, 2017, 11:59:51 AM »
You are correct and I should have differentiated the older core series units from New MEGA units having a dedicated DI channel  ...
I missed the OP designation his unit was MEGA  ...
« Last Edit: September 21, 2017, 09:03:28 AM by rnvinc »
Offline ckd022
  • Software: 5.840
« Reply #8 on: September 20, 2017, 12:10:13 PM »
Given that there are both SI and a separate DI transducers on this particular unit, I'm back to wondering if that B004 is the new dedicated DI sonar data and that after B004 was deleted, Humviewer is showing the port SI data "rotated" to look like a down image.
My guess is that Humviewer just keeps loading B00x files (incrementing x starting at 1) until it cannot find a file with that name, then it begins processing the data.  It obviously tried to read the B004 file when it was in the directory, but I'm guessing there was something in the format of the data that didn't "match" Humviewer's pre-programmed file types (since this transducer was created long after Humviewer stopped being updated).
Kevin
Offline zeebeest
« Reply #9 on: April 15, 2018, 03:31:51 AM »
I bought a Helix SI Mega but now I get also the message "This is not a valid Humminbird Sonar recording file.
 Cannot find type for file : B004.SON".
It was working perfect with my 1198 .
Wat can I do ?
« Reply #10 on: April 15, 2018, 10:29:14 PM »
Wat can I do ?
See Reply #3 above (in this same thread) where Mc Cloud deleted the B004 file before trying to load into Humviewer  ...
Thx.
« Last Edit: April 15, 2018, 10:30:56 PM by rnvinc »
Last post December 28, 2009, 08:53:19 PM
by Crispen
Last post January 24, 2010, 09:00:52 AM
by George
Last post September 11, 2010, 05:50:29 PM
Last post May 31, 2012, 05:29:15 PM
by Ricky
Last post January 25, 2013, 11:27:56 PM
by okiedokie
Last post September 03, 2014, 09:59:11 PM
by Smellybox
Last post August 05, 2016, 05:23:10 PM
by Scampbell
Last post June 11, 2017, 08:12:16 PM
by fshndude
