Author Topic: Illegal Data error :(  (Read 20241 times)
Offline john h
  • Unit(s): 798cxi
« on: July 12, 2009, 05:53:21 AM »
Hi Martin,
I went to review my recording from today and yesterday and some of them produce an Illegal data error :(
I am able to view these same recordings in Yellowfin and SIView (after converting to the right format).
Is there anything I can do?
Offline Macca
Re: Illegal Data error :(
« Reply #1 on: July 12, 2009, 02:43:57 PM »
Hello John,
 I can't help you with your problem. Just wondering if you are happy with your 798cx are  you having problems with the screen going black after you hit 20ft water. I have just purchased the 798cxi si but have not had a chance to use it yet. All I have read lately is doom & gloom. Hoping you can shed some light on this subject.
Cheers Tommy Sydney Australia
The Cook
Offline john h
  • Unit(s): 798cxi
« Reply #2 on: July 13, 2009, 04:27:19 AM »
I haven't used mine in a lot of deep water yet but I did go over a 30 foot hole on the weekend and the image was displayed no problems.
Offline Macca
Thanks John
« Reply #3 on: July 13, 2009, 05:29:30 AM »
Thanks John I appreciate your comment. I hope I can post some good pic's & comments when I get up and going. Do you have any side image pics. What area do you fish.
I hope to post my side image pics on the link below soon with my other hobby I love to cook spit roasts & Cobb cooking
http://www.flickr.com/photos/8188630@N03/
Cheers Tommy from downunder
The Cook
Offline mrj9600
    • Home of HumViewer
  • Unit(s): 997C SI
  • Software: 6.300
  • Accessories: Speed sensor
« Reply #4 on: July 13, 2009, 10:58:26 AM »
Hi John
It was a guard that I added to the program after I received some recordings were one of the recording files only contained a few records. This made the program freeze.
But I have later found out that it is actually quite normal that there is some difference in the number of records, so I have changed the limit for accepting the recording files. Also I have changed the program so the dialog that is shown is just a warning. So when I release the next version this problem should be solved.
/Martin
Offline john h
  • Unit(s): 798cxi
« Reply #5 on: July 14, 2009, 04:47:12 AM »
Thanks Martin
Offline Rickard
HumViewer won't start anymore - sorry ran the wrong version by mistake!
« Reply #6 on: August 08, 2009, 05:39:07 PM »
Hi Martin!
Tack för ett förträffligt program! (Thanks for an excellent program). However, my Humviewer refuse to start after I aborted (closed the program) before it had finished loading a very long file. I'm not sure if I have installed the program correctly, there is no icon and the program is not listed in "all programs" so I have to go to the HumViewer catalog and click the executable Jar-file. When I load the runHumviewer command file a DOS-window is displayed and the first row reads: "Fatal error, premature end of file". These are the clues I have. I have Vista Home. I have restarted the system. Version is 1.001
Added: I accidentally ran an older version. The latest version works alright! Sorry for any trouble!
Regards from Uppsala
Rickard
« Last Edit: August 10, 2009, 08:10:10 AM by Rickard »
Offline Crispen
  • Unit(s): 797c si
« Reply #7 on: December 28, 2009, 05:07:48 AM »
Hello Martin
I likewise ran into the same problem, whenever I try to load a file larger than a few seconds, I get a error message "illegal data" associated with two different time stamps within the file.  This error message repeats 4 times and while the first number is consistent, the second number is always slightly less and varies across each of the four errors messages.
I was wondering when you might have the next version ready? I really look forward to using your software.
Best regards
Crispen
Offline George
  • Software: Always up todate
« Reply #8 on: December 28, 2009, 08:31:35 AM »
Initially I had this problem and removed Humviewer and reinstalled Humviewer and everything works fine.
George
Offline Crispen
  • Unit(s): 797c si
« Reply #9 on: December 28, 2009, 08:53:19 PM »
Thanks George, I'll give it a try.
Last post September 28, 2010, 12:47:04 PM
Last post January 31, 2011, 01:31:22 PM
Last post May 31, 2012, 05:29:15 PM
by Ricky
Last post September 10, 2012, 08:52:40 AM
by gros21
Last post December 11, 2012, 02:33:03 PM
Last post September 03, 2014, 09:59:11 PM
by Smellybox
Last post November 20, 2013, 05:27:51 AM
by lars
Last post April 15, 2018, 10:29:14 PM
