Author Topic: Helix 10 views help?  (Read 9858 times)
Offline fishinman
  • Unit(s): 1
« on: August 30, 2017, 04:16:06 PM »
When I scroll over to "views" on my Helix 10, not all the available views are showing up...
What am I missing or need to do?
Re: Helix 10 views help?
« Reply #1 on: August 30, 2017, 08:27:47 PM »
2 possibilities  ...
*Chart views will not be available until the satellites are acquired by the unit  ...
*The Connected Transducer Menu under the Sonar tab has been changed to a different xducer than the stock xducer  ...
Restore Defaults will set the Connected Transducer back to the factory setting if you don't know which xducer came with the unit  ...
Which HELIX 10 do you have  ...??
« Last Edit: August 30, 2017, 08:30:11 PM by rnvinc »
Offline fshndude
« Reply #2 on: August 30, 2017, 09:02:03 PM »
Do you have all the views turned "on"? When I turned mine on I had to tell it what views I wanted and didn't want.
Dave in Currituck,NC
« Reply #3 on: August 30, 2017, 09:53:50 PM »
Also make sure you are in advanced mode.
Offline fishinman
  • Unit(s): 1
« Reply #4 on: August 30, 2017, 09:57:19 PM »
Thanks for the replies.... I will look into all of those.... I'm inclined to think it's either the satellite acquisition or transducer...will let you know...
Again, thanks
Gary
Offline fishinman
  • Unit(s): 1
« Reply #5 on: September 02, 2017, 02:12:37 PM »
Yep.... Was on wrong transducer.... Beats me how it got changed...all is good...
Thanks, guys!
Gary
Last post September 26, 2011, 11:27:01 AM
Last post February 06, 2012, 02:16:30 PM
Last post April 24, 2012, 08:23:33 AM
by 6speedy3
Last post May 13, 2012, 03:18:10 PM
by Turk
Started by Fay 798c SI
Last post June 16, 2012, 09:22:42 AM
by Fay
Last post June 06, 2017, 10:40:03 AM
by grizwilson
Last post April 14, 2019, 08:59:43 PM
Last post March 15, 2024, 06:00:02 PM
by Bayou Basser
