Author Topic: How long can you record?  (Read 14874 times)
Offline twobearlake
  • Unit(s): 798csi
« on: March 28, 2010, 08:41:33 PM »
I was wondering how long you can record sonar data on a 4gb sdhc card?
Thanks,
TB
Re: How long can you record?
« Reply #1 on: March 28, 2010, 09:44:33 PM »
Well, you can record until the 4gb runs out!  ;D
There are several factors to recording size that will affect how long you can record.  The range is probably the biggest factor.  The larger the range setting the more bytes that are recorded per ping.  Also, if you have the 83khz transducer enabled.  A file is recorded for each transducer, so having it enabled will add 33 percent more data to the recording.
Typically 4 gb SD card can record for hours at say a 100' range setting.  I would suggest breaking it up in to 30 minute recordings if possible.  If you plan on playing it back on the computer, most softwares right now cannot handle very large files.
Hope this helps,
Offline twobearlake
  • Unit(s): 798csi
« Reply #2 on: March 28, 2010, 10:12:31 PM »
Very helpful.  Thanks!     :D
TB
Offline George
  • Software: Always up todate
« Reply #3 on: March 28, 2010, 10:41:31 PM »
I agree with Robert about breaking it up into 30 minute segments, I have done a 1 1/2 hours and it takes a long time to load it for viewing.  With 30 minute segments you can easily get a whole day out of the 4 GB chip.
George
Offline dybvad417
  • Wreckhunter in the Kattegat, Denmark
  • Unit(s): 987 Cx SI
  • Software: 4.750
« Reply #4 on: March 29, 2010, 02:23:26 AM »
Hey
I have a  Record.
Length:  1 hour  47 min.
SI range: 95 meters  both sides.
Max depth:  46 meters
Total size for all .IDX and .SON files:  664 MB .
Regards
Gert
« Reply #5 on: March 29, 2010, 08:34:24 AM »
Well, if you review on the unit that is 1hour & 47minutes of playback.  Not to mention how hard it is to go to different places on the recording playback.  That large of file will take a while to load to a computer and then a viewer like humvierew or yellowfin will take a very long time to load. However once it is loaded you can skip around in the recording with out much delay.  Most recordings should not exceed 30 minutes.  Remember also that while recording you cannot take a snapshot.  chuck
Offline twobearlake
  • Unit(s): 798csi
« Reply #6 on: March 29, 2010, 10:59:12 PM »
Thanks to everyone for the posts.  That is exactly what I was asking.  The tip to break up the recordings makes a lot of sense - thanks.
I will go with the 4gb card.
TB
Last post September 22, 2011, 03:56:09 PM
Last post May 13, 2012, 03:18:10 PM
by Turk
Last post May 21, 2012, 07:36:48 PM
by C. Corner
Last post February 20, 2013, 06:36:05 PM
Last post August 21, 2013, 08:23:39 AM
by maachuu
Last post September 08, 2013, 04:36:30 PM
by maachuu
Last post February 01, 2016, 04:47:02 PM
by Rickard
Last post June 11, 2015, 10:58:47 PM
by Bubba Canuck
