Author Topic: Helix si and puck transducer y cable  (Read 9955 times)
Offline NovaSS
  • Unit(s): humminbird lcr4000 and 541
  • Software: oem
  • Accessories: just fish finders for now
« on: June 15, 2017, 01:13:52 AM »
I read alot of people use a y cable to install a puck transducer to read at high speeds. but they install the si transducer to where its out of the water while on plain. but wouldnt that hurt the transducer if it out of the water? Im confused on this subject.
something like this
Re: Helix si and puck transducer y cable
« Reply #1 on: June 16, 2017, 09:06:36 AM »
It's unlikely our low wattage SI xducers would be damaged by transmitting while out of the water  ...
Those scenarios are more commonly heard of in the high wattage CHIRP xducers (2-3Kw) that can generate heat and need the water as cooling for the housing  ...
It is possible to easily shut off the imaging piezoes (in the SI xducer) by selecting "HB 83/200kHz" in the Connected Transducer Menu under the Sonar tab (if one feels more comfortable doing so)  ...
« Last Edit: June 16, 2017, 09:07:42 AM by rnvinc »
Last post April 14, 2010, 01:50:54 PM
Last post February 18, 2012, 10:49:25 PM
by choc_e
Last post October 30, 2012, 01:51:28 PM
Last post December 06, 2012, 11:56:16 AM
by Consigliere
Last post August 05, 2013, 09:05:03 PM
by bobcoy
Last post November 23, 2018, 09:52:54 PM
by henz
Last post December 14, 2019, 12:12:02 PM
