Author Topic: 797 c2 si puck transducer part number ?  (Read 8503 times)
Offline RayinVa
« on: April 12, 2010, 08:13:47 PM »
I see there is no listing for the puck shoot thru the hull transducer at the humminbird site ,  anyone know the part numbers ? I have read that some say the 798 model was different , all help greatly appreciated .
Ray
edit: Im thinking the part number is XP 9 20    not sure if the quad beam works or not  ..
« Last Edit: April 12, 2010, 08:34:59 PM by RayinVa »
Re: 797 c2 si puck transducer part number ?
« Reply #1 on: April 14, 2010, 01:50:54 PM »
The XP-9-20 is the correct transducer to use if you need an inside-the-hull 2D sonar transducer to use with your 798 unit.  You would need the AS-Si-DB-Y to connect this and the Si transducer to the 798 unit.
Last post February 18, 2012, 10:49:25 PM
by choc_e
Last post September 17, 2012, 02:33:40 PM
by Trytoofish
Last post October 30, 2012, 01:51:28 PM
Last post August 05, 2013, 09:05:03 PM
Last post November 07, 2014, 03:04:18 PM
Last post June 16, 2017, 09:06:36 AM
Last post June 23, 2019, 09:39:59 PM
by Sodaksam
Last post November 08, 2023, 06:14:56 PM
by proskeeterman@comcast.net
