Author Topic: 2d sonar NOISE  (Read 8322 times)
Offline kfield65
  • Unit(s): Helix 5 SI GPS
  • Software: 7.73
  • Accessories: Autochart Pro
2d sonar NOISE
« on: May 06, 2017, 12:25:52 PM »
helix 5 si gps has top 5ft of water depth coloured all the time ??
Re: 2d sonar NOISE
« Reply #1 on: May 06, 2017, 11:58:12 PM »
Are you using an additional "shoot thru" 2d xducer and the AS SIDBY Cable... or only the stock SI xducer  ...
« Last Edit: May 07, 2017, 12:00:45 AM by rnvinc »
Offline kfield65
  • Software: 7.73
Re: 2d sonar NOISE
« Reply #2 on: May 08, 2017, 08:27:43 AM »
just the stock xducer. Didn't have this noise last year was thinking may be a ground problem
Re: 2d sonar NOISE
« Reply #3 on: May 09, 2017, 10:19:47 PM »
It may be an algae bloom  ...and can be worse if the 83kHz beam is being used  ...
Can you try the 200kHz Beam Frequency to see if there's any change  ...??
Offline kfield65
  • Software: 7.73
Re: 2d sonar NOISE
« Reply #4 on: May 10, 2017, 08:19:39 AM »
I only use the 200hz. Water was clear down to 8+ft.Didnt see this last year don't know if when putting everything back in my boat from winter I may have picked up some ground problem. It is on the crank batt with the other accessories but didn't have it last year. Puzzling .Thanks for your input though keeps my mind working
Re: 2d sonar NOISE
« Reply #5 on: May 10, 2017, 09:52:39 PM »
The best troubleshooting is to try your head unit on another xducer  ... Or try another head unit on your xducer  ...
Offline kfield65
  • Software: 7.73
Re: 2d sonar NOISE
« Reply #6 on: May 11, 2017, 11:48:37 AM »
Rickie I check what I thought I had set for my xducer was at 200hz only but you are correct it was on 200-85hz setting and in the driveway of my house the noise went away. I will see on sat when I hit the lake . Thank You
Re: 2d sonar NOISE
« Reply #7 on: May 11, 2017, 11:47:36 PM »
Please post results so we can troubleshoot more if needed  ...
Humminbird is also a good resource (Monday thru Friday of course)  ...
1-800-633-1468
Last post August 05, 2011, 04:25:21 AM
by goodwinexplorer
Last post April 09, 2013, 06:42:19 AM
Last post June 28, 2013, 09:57:52 AM
Last post July 10, 2013, 10:16:36 AM
Last post September 10, 2013, 11:32:25 AM
Last post January 10, 2014, 10:23:44 AM
by Mike_Sea
Last post May 29, 2014, 09:50:37 AM
by gofission
Last post May 09, 2020, 10:17:30 PM
