Author Topic: Mechanical Noise  (Read 16971 times)
Offline Mike_Sea
  • Unit(s): 1198cx si combo
Mechanical Noise
« on: January 07, 2014, 04:31:21 AM »
As you can see this is not usual picture of a SI. There're some noise and mechanical obstruction.
Using Kingston SD HC card 10 class
Why this is happened?
Re: Mechanical Noise
« Reply #1 on: January 07, 2014, 05:54:41 PM »
Mike,
Did you play this file back on the Humminbird unit?  Do you get the same thing?
This is not at all what it shoud look like and is more than mechanical or noise issue!
Play it back on the unit and take some snapshots and post back here.
Offline Mike_Sea
« Reply #2 on: January 08, 2014, 07:18:12 AM »
Robert,
Here's a snapshot in att.
There are no noise and picture is clear.
Also, when I'm play record my Humminbird 1198cx si Combo, and click on "FF Play" its restarts.
While paying record I click on "View" button, and its restarts as well.
But sometimes play ok..
Mike
« Reply #3 on: January 08, 2014, 07:54:45 AM »
Take a 5 minute recording and then download humviewer from this site and view the recording on a computer. Viewers use the raw data recorded to display the screens. It is probably a better playback detail than the HB playback feature in the unit.
Also make sure the boat is moving during the recording and not sitting still..
chuck
Offline Mike_Sea
« Reply #4 on: January 08, 2014, 08:37:34 AM »
Chuck,
I make more than 20 min rec.
Is there a max time limit?
Mike
Offline LittleGazoo
  • Software: 3.640
  • Accessories: Ethernet
« Reply #5 on: January 08, 2014, 10:49:39 AM »
Depends on the SD-card size.  Your can record and re-record until the SD-card is full.
« Reply #6 on: January 08, 2014, 01:20:28 PM »
Card size determines to a point the time you can record. However for your problem I was suggesting a 5 min record. That should give enough information to help with your problem..
chuck
Offline Mike_Sea
« Reply #7 on: January 08, 2014, 04:07:42 PM »
I've got a Kingston 16 GB 10 Class SD HC card.
Tomorrow going to a lake to test. Also done a full format.
« Reply #8 on: January 09, 2014, 08:10:32 AM »
Mike, download humviwer and look at your recording on the computer. let us know what you see..
Here is the link to get humviewer.. http://humviewer.cm-johansen.dk/
chuck
« Last Edit: January 09, 2014, 08:12:49 AM by sonar2000 »
Offline Mike_Sea
« Reply #9 on: January 10, 2014, 10:23:44 AM »
Today I've done a record for 2h and it pays well in HumViewer
Also I've downloaded and using:
HumminbirdPc
HumFinder
HumMapper 2.1
SI View
Son2xtf
DeepView
Thank all of you for advices!
Mike
Last post August 05, 2011, 04:25:21 AM
by goodwinexplorer
Last post August 08, 2012, 01:41:44 PM
by Rüdiger
Last post June 28, 2013, 09:57:52 AM
Last post July 10, 2013, 10:16:36 AM
Last post September 10, 2013, 11:32:25 AM
Last post May 29, 2014, 09:50:37 AM
by gofission
Last post March 16, 2016, 09:23:27 PM
by tambrose76
Last post May 09, 2020, 10:17:30 PM
