Author Topic: Transducer Upgrade  (Read 15239 times)
Offline Undismal Nitch
  • Unit(s): 899ci HD SI
Transducer Upgrade
« on: January 04, 2015, 02:57:07 PM »
This is my first post and appreciate all the info. that is out there. I just purchased the 899ci HD SI and it came with the XNT 9 SI 180 T transducer. Is it worth the upgrade to the XHS 9 HDSI 180 T? I have a welded aluminum jetboat and will need two transducers so cost is an issue. I fish mostly rivers for salmon and stripers. Thanks in advance for any help.
Re: Transducer Upgrade
« Reply #1 on: January 04, 2015, 05:50:38 PM »
There are 2 distinct advantages to upgrading to the XHS 9 HDSI 180 T ...
*Longer SI piezoes in the XHS 9 HDSI 180 T create a thinner beam slice = sharper detail ...
*XHS 9 HDSI 180 T has the capability of the added HI-DEF 800kHz SI frequency ...
Yes it's worth it ...
You will need the AS SILR Y cable for a dual xducer setup because of your jet ...
*Right SI, 2d, and Temp would come from the starboard XHS 9 HDSI 180 T ...
*Left SI would come from the port XHS 9 HDSI 180 T ...
« Last Edit: January 04, 2015, 05:54:26 PM by rnvinc »
Offline bgump24
  • Unit(s): 899 SI
« Reply #2 on: January 05, 2015, 06:44:31 AM »
yes its definitely worth it
« Reply #3 on: January 05, 2015, 05:43:23 PM »
Thanks for the replies. Looks like I am definietly going to upgrade
Offline born 2 fish
  • Unit(s): 1199 898
  • Software: 7.460/6.49
  • Accessories: I-PILOT LINK
« Reply #4 on: January 05, 2015, 06:37:32 PM »
It is worth the upgrage if you did not open your transducer humminbird will trade it in on the hdsi transducer to save you some money.
Offline JoeyWelch
  • Unit(s): 899ci
« Reply #5 on: January 05, 2015, 08:33:08 PM »
I have the same machine and I am thinking about upgrading also. Will we have to send our machines in for hardware modifications?
Offline born 2 fish
  • Unit(s): 1199 898
« Reply #6 on: January 05, 2015, 08:41:16 PM »
[/quote
No you do not have to send your unit in just plug in the transducer and your set.
Offline mustang99
  • Unit(s): 899 si
« Reply #7 on: January 08, 2015, 06:25:10 PM »
It's worth it!!!!
Offline sfw1960
  • Bringer Of The 'Bird
« Reply #8 on: January 09, 2015, 02:12:28 PM »
Last post February 08, 2011, 05:53:53 AM
by SaminVa.
Last post May 18, 2013, 12:25:10 PM
by Lake Diver
Last post May 23, 2014, 11:27:53 PM
by rsouza3
Last post May 23, 2014, 11:28:41 PM
by rsouza3
Last post February 28, 2015, 06:51:54 AM
by mako101
Last post December 06, 2017, 09:23:34 PM
Last post February 26, 2017, 01:41:48 PM
by edwin81
Last post April 14, 2020, 08:31:19 AM
by Philip Brown
