Author Topic: Onix not able to read SD card with Nav data from Humminbird PC  (Read 21837 times)
Offline aholzhausen01
  • Unit(s): 898c SI, Onix 10 CI Combo
  • Software: Onix has 1.150
Installed my new Onix 10 CI Combo and had problems reading the LakeMaster cards.  Finally started to work with no known relationship to the actions I tried.  That part is working now.  I then downloaded my old waypoints and tracks from my 898C SI using Humminbird PC to an SD card.  I confirmed that the correct data was on the SD card in Humminbird PC.  When I put it in my Onix and go to files to upload the data, my Onix doesn't see any data.  When I check it says that the card does not have humminbird data.  I'm wondering if I have a problem with the card reader in my Onix since I keep having these problems.  Any advice out there?
  • Moderator
Re: Onix not able to read SD card with Nav data from Humminbird PC
« Reply #1 on: April 28, 2014, 02:44:57 PM »
What is the file name and type on the SD card?
The ONIX/ION units use a *.GPX file format, so when using HummibirdPC you need to save your Nav Data as a *.GPX file and use your PC to save it to the SD card.
« Reply #2 on: April 28, 2014, 03:18:58 PM »
Thanks Greg,
I was using the normal upload function of Humminbird PC and getting a matrix folder with DATA.HWR,  001.ht, and   000.ht files.  I used the "save as" function to save the .GPX files to the card and the Onix loaded them.  Problem solved.
Last post March 31, 2013, 09:44:32 PM
by Rough House
Last post December 03, 2013, 10:36:26 PM
Last post January 08, 2014, 10:33:08 PM
by Nitro78
Last post April 25, 2014, 12:54:28 PM
Last post April 02, 2015, 08:41:23 AM
by nwifishnut
Last post July 09, 2015, 03:13:47 PM
by CamoHunter
Last post March 02, 2016, 11:25:45 PM
