Author Topic: HBSI SONAR FILE CONV. NEED HELP  (Read 17255 times)
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
« on: March 14, 2010, 12:56:59 PM »
I noticed when i convert my HB sonar files with HBSI file conv. an check the box to play
the file. The YellowFin recorder is not a updated recorder. But if i open my YellowFin recorder on
my dest top and play the same recorder thats in my doc. it is a updated recorder whats up?
Gary
Re: HBSI SONAR FILE CONV. NEED HELP
« Reply #1 on: March 14, 2010, 01:01:57 PM »
Most probably the result of having two yellowfins.  Unless you find it necessary I would rename the old YF or delete it.  what levels of YF are you running???    I will check some more on this.   chuck
« Last Edit: March 14, 2010, 01:03:50 PM by sonar2000 »
Offline stillbear
  • Stillbear
« Reply #2 on: March 14, 2010, 02:14:40 PM »
No i deleted and reloaded every thing new same thing is happening my converter is 109c the new update brings it up to nov.2008 i think. but if you convert a file and check the box to start playing
when finished converting. The player is the origanal downloaded player that is not updated.The date is like 2006. How do i get the HBSI SONAR CONV. to use my updated yellowFin player when
i check the box to play when done converting.  Thanks Gary
« Reply #3 on: March 14, 2010, 09:09:19 PM »
If I am not mistaken, I believe you are supposed to copy over the old .exe with the updated one.
I just checked and in the download there should be a file that says, READ ME FIRST.
Quote
Replace the file YellowFin.exe in the main folder using the one in the folder named "Update V2.0"
The main folder is standard installed in C:\Program files\Imagenex\YellowFin
Hope that helps.  It should fix the problem.
Offline stillbear
  • Stillbear
« Reply #4 on: March 15, 2010, 10:51:54 AM »
Robert sorry my ignorance I am learning you were right works perfect.  Thanks Gary
« Reply #5 on: March 15, 2010, 12:29:53 PM »
No problem!  ;D  I did the same thing when I first upgraded mine!  ;)
Last post June 18, 2015, 01:22:52 PM
by Fishboch
Last post February 12, 2010, 08:30:15 PM
Last post August 21, 2012, 11:30:17 PM
by LLCC
Last post May 11, 2011, 12:49:14 PM
Last post February 12, 2014, 07:35:34 PM
Last post September 02, 2015, 04:29:51 PM
by norj
Last post February 13, 2017, 09:04:17 AM
Last post September 18, 2019, 10:50:41 PM
