Author Topic: Running a Helix 5 only as plotter  (Read 7358 times)
Offline Kablars
« on: January 07, 2017, 01:49:47 PM »
Hello, i was wondering if i can run my Helix 5 SI GPS only as a plotter without a transducer attatched? Or will it just enter demo-mode?
I have a better unit for both sonar and SI/DI but no plotter.
I have very litte experience with this kind of things.
Any help much appreciated.
Thank you.
Re: Running a Helix 5 only as plotter
« Reply #1 on: January 07, 2017, 06:35:14 PM »
*Power on the unit ... (with or without the xducer attached) ...
*Press "Menu" when the HB logo appears ...
*Choose "Normal" from the popup ...
*Right cursor to activate Normal operation ...
*When the unit has fully booted up - press the power button briefly ...
*Choose "Sonar Off" from the popup window ...
This shuts off the transmitters and allows the unit to be used as a chartplotter only ...
I'm not sure if your model unit will remember this setting change upon a power cycle and reboot ... so test the procedure above after power cycling the unit ...
« Last Edit: January 07, 2017, 06:37:49 PM by rnvinc »
Offline Kablars
« Reply #2 on: January 08, 2017, 10:58:59 AM »
I will try, thanks alot!
Last post March 24, 2010, 01:42:13 AM
Last post May 18, 2010, 12:50:56 PM
Last post January 01, 2013, 12:17:23 PM
by kosmo
Last post March 11, 2014, 11:14:03 AM
Last post February 09, 2015, 02:44:40 PM
Last post May 13, 2015, 12:55:42 PM
by Gimp
Last post October 23, 2015, 10:41:56 PM
Last post October 08, 2016, 10:09:16 PM
by Rpadar
